The instructions for my Olevia television said that a Video Game System needs to be plugged in S-Video. However I have tried that and every other input mode on the television and they all say "No Signal." Can someone help?
SOURCE: Olevia 27" television
In the owners manual it will explain how to get to the language menu, then shifr through it till you see english and click on it. If that does not help, go to the store where you bought it.
SOURCE: Can't hook up playstation 2 to my Toshiba HDTV
You need to put the tv in AUX 1 or AUX 2 channel. (wherever you plugged in the game)
SOURCE: Powers on but no video display
I think I have a similar problem. The screen lights up, but I have thin vertical lines, mostly washout out by white toward the top. However, I can hear the TV programs even as I surf up and down through my channels.. If I change inputs, it seems to cycle through each mode, and I am able to get back to the TV input, but the display does not change.
SOURCE: My Olevia 27in. LCD Television does not turn on
Well, at least the standby 5vdc circuit is still working but the problem can be in the controller board is not sending the signal to turn on the main power supply sections, or the power supply itself is bad. Look at the power supply first for burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: How do you connect a Nintendo 64 game station with
connect the AV cable to the red white and yellow input outlets on the tv and press input on your remote you have to be on video 1, 2, or 3 to play the nintendo 64
my playstation 3 does not work with my Olevia 532 through my hdmi cable. It does work with the composite cable that came with the playstation but not with hdmi. when i first got the playstation it worked perfectly but after a while it just stopped.
i am having the same problem with my olevia 427
