Question about Vivitar ViviCam 4100 Digital Camera
Unable to transfer pictures to Computer.
Whilst on holiday I took 240 photographs.Then I went to take one more.I slid back the On/Off slide and the LCD monitor did not light up.I could not take any more oicyures and I cannot download to my Computer what is already on the S.D.Card.
I have put in brand new battteries but it will not light up or show any sign of life.
Can you help me please.
Can I put the S.D.card in another camera and down load that way.But I need to get this camera working.
Thank you,
Peter Kisby
I believe you can do that, it should not be a problem ( moving your sd card to another camera). Worst case scenario, you would have to go buy an sd card reader ( pretty cheap, probably won't have to spend more than $50 for it, not even that) and take the sd card out and put it in the reader and download from there. Good Luck!
Posted on Dec 21, 2008
Photograph Transfer. Unable to transfer from VAIO
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Feb 09, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
I've taken the seating off of the Graco stroller but am unable to take off the back basket and the rain cover. Please help.
Not sure which model you have, but we just took ours apart. I unscrewed the rain cover (two screws on each side) and the cover slides off. I immediately put the two metal bars back in (with screws) so as not to lose the parts.
Our basket has several snaps to undo, then the basket pops off at the hinge point (toward the front wheels). There was a little button to press in on either side and it just pulled back and slid out. Then the basket slid off so we could clean it.
Hope this helps you out. Good luck!
May 16, 2009 | Graco Quattro Tour Travel System
Trouble with transfer to my computer
Try this attach you USB cable to the Computer and Camera. It should find the device and download the pictures itself. That is how it works for my Canon powershot A 80.
Below is the CANON support wesite for your model Camera.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=14904
Jan 07, 2009 | Canon Cameras
Data transferring trouble
do you set in options MASS STORAGE? if your display show u wallpaper u have setted as DATA TRANSMISION! go to menu press9 then 4 then 3 and 2 :) greets
Nov 02, 2008 | LG Shine KE970 Cellular Phone
D80 ERR & CHR message
Hello Michaela1,
There are a few things I can recommend:
1. Please check your card on some other camera to make sure the media is alright.
2. I am not sure if you take the SD card out of the camera and put it into a card reader (stand alone, in your laptop/PC) to read the images. As I understand, you first took out the card and then put it back into the camera to read from the camera once it did not work in the card reader. However, there are issues with doing both. I will outline them below.
  • Card Reader: At times, reading a card in a card reader will mess it up and it will remain unusable in the camera even if it displays photographs on camera LCD. Please note, this will happen even if you have only viewed the photographs on your computer and not saved them to your hard drive/media. The card will most definitely not work in camera if you delete photographs from the card or edit them on the card. The only solution to this is to format that card IN the Camera. The manual has instructions for the same.
  • In Camera: Other times, you may have connected the camera through the USB cable to a computer with the card in the camera. This problem may crop up IF you used your computer to delete images from the card whilst it was IN the camera. Again, the solution is to format the card. IN the camera, not from the PC.
3. Whether you use the USB cable or take out the card and put it into a card reader to save your photographs, always repeat ALWAYS format your card in the camera after transferring your photographs. This ensures card will not malfunction unless the media is corrupt. This also has the added benefit of not having the same photographs a few times over.
4. Try not to leave your images in the card after taking photographs. Try to save them to your PC at the earliest opportunity. Format after-wards (I can not repeat this point enough).
5. Use multiple cards of smaller capacity. They are cheaper to buy. Even if you lose one card to a mal-function, you still have photographs on others.
I hope this helps.
Satdeep
May 31, 2008 | Nikon D80 Digital Camera with 18-200mm...
Memory card locked!??
What you need to do is take out the card, and on the side of it there should be a little gray thing which can slide up and down. It needs to be slid all the way up. I hope this helps!!
Dec 26, 2007 | Pentax Optio W10 Digital Camera
320 x 240 dpi Photo Transfer Problem
Certain computer hardware and software configurations conflict with PhotoMAX or PhotoImpression software. As a result, you may not be able to transfer 320 x 240 dpi photos from your Polaroid Fun! Flash 640 digital damera. This problem does not occur if you use the camera's default resolution of 640 x 480 dpi.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Vivitar ViviCam 4100 Digital Camera Logo
143 people viewed this question
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
James Woodgreaves
James Woodgreaves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
