There is a constant smell of oil in the house although central heating is still working and radiators are hot
  • 126 Answers
IF THE UNIT IS WORKING AT OPTIMUM PERFORMANCE THER IS NO GAS LEAK IT MIGHT BE MOISTURE OR SOME OTHER BAD SMELL GET THE APPLIANCE SERVICED AND CLEANED
Posted on Sep 16, 2008
Have oil heater that we had serviced yesterday. Heater stays at temperature but circulating pump will not send heat to upstairs radiators. (heater in basement) Any advice?
Try putting in central heat and air in your house don't rely on some basement heater then you will have a basement heater for when it get cold
Dec 03, 2013 | Lakewood Oil-Filled Electric Radiator...
1997 nissan pathfinder smells hot after running awhile
Check your valve cover gaskets, bet they are leaking and that is burning off.
Jun 27, 2017 | 1997 Nissan Pathfinder
Air compressor will not start.
When you are texturing walls you need a texture machine, they work very differently from an air compressor. An air compressor, especially one as small as the Central Pneumatic 40400 cannot supply the constant flow of air required by texture guns. If your compressor was running long enough to get hot enough to smell it then stopped working some of the possibilities are:
- Popped a circuit breaker, either the house breaker for the outlet you were using or the breaker on the compressor motor. This usually occurs because the compressor is being run on a too small guage or too long extension cord or run constantly for an extended period.
- Motor got overheated and seized up or shorted out. This could be as simple as a bearing seizing or as bad as the coils in the arnature shorted out.
- Pump may have seized up. Even if the sight glass shows the crankcase is full, the condition of the oil and its ability to lubricate are greatly affected if it is overheated.
Mar 13, 2012 | Chicago Pneumatic Air Tools & Compressors
ENGLAND, UK. DOMESTIC HOUSE CENTRAL HEATING. Baxi Bermuda
try bleeding the radiators in the order of downstairs first and then the upstairs and try to bleed them in the order they fill, trapped air can take a while to escape, a good sign on a radiator is the bottoms being warm where the tops( where the air is trapped) stays cooler, a sure sign to which radiator needs bleedin, hope this helps, colin
Apr 02, 2010 | Heating & Cooling
Central heating pump is very hot radiators not
need to bleed radiators or pump impellers have damage
Feb 01, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
Excellent - glad it helped .. Please feel free to leave feedback
Feb 01, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Heat gauge shows hot , have to add antifreeze although no leak
Very common fault is head gaskets.  causing coolant consumption and bubbles in radiator.  Run vehicle, have a friend accelerate once or twice hard, while you smell exhaust for sweet smell of burning coolant.
Dec 18, 2008 | 1997 Ford Taurus
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Heating & Cooling Logo
160 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
