Question about Whirlpool Calypso GVW9959K Top Load Washer
CA Error Code - AEG OKO LAVAMAT 86700
New motor has been installed but CA error code reappears. Please can you advise which part of the machine is causing this error.
Thanks
Harvey
  • pacolopez37 Jan 12, 2009
    An error CA appears in display what can I do ?
C-a error message poped-up.washer stop working.............please help.
Posted on Nov 18, 2008
How do I fix my washing machine
If your washer was working previously please read below.
Thermal Overload Protection
Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Jan 06, 2015 | Washing Machines
WHAT DO IF I HAVE AN ERROR CODE E7-03 ON MY SHARP PRINTER MODEL NO ARM620N
The code refers to a hard drive issue. This could be caused by a corrupted file or there is an issue with drive itself. First thing to try is to reset the error code. This sometimes works & the machine runs fine after. If the code returns then you could be looking at a new hard drive.
To reset the machine, make sure the copier is in COPY mode, then press the following 4 keys in sequence #*C*
The machine should now be in simulation mode. Enter 14 then press the copy start key. Press the copy start again then press the CA key. The machine should reboot & if the drive is ok the machine should be ready to copy. If the code reappears the its most likely the hard drive is faulty.
Dec 27, 2014 | Sharp Office Equipment & Supplies
Why is my Maytag washer showing lr code again?
If you live in North Hollywood, CA and need washer repair service call us at (626) 460-0903 or visit our website Washer Repair North Hollywood CA 747 248 4544 Samsung
Sep 03, 2017 | Washing Machines
ERROR F 03 EN COPIADORA SHARP MX363N
If this is the code F1-03 then you have motor trouble within the finisher that I am assuming is fitted to your machine. Try entering this code to reset it.
Press # * C * and when the screen asks for a simulation number type in the number 14. Now press the start button (the key you press to make a copy). On the screen press execute and then confirm yes. Once you have done this press CA.
This may help but if a motor has failed its likely that the code will reappear.
Good Luck
Follow me on Twitter @CDOS_Service
Jan 13, 2014 | Sharp AR-M450N Copier
Calypso kenmore washing machine faulty spin cycle ''CA'' code
This code signifies that there may be a problem with the motor, thermal protector or motor controller. Overloading the appliance may cause such an error code. Try using a smaller load. If the code reappears, contact an appliance service company.
Apr 13, 2010 | Kenmore Washing Machines
I have a ca code what does this mean
Hi
Thanks for using FixYa. Error code CA means Average current limit. This error code will display if the load of clothes is more then the normal load. Also if current limit breaches then status signal comes back from the motor controller. The unit will return to standby mode and display CA. Average current trip occurs if the current draw at the motor windings is greater than 5.55 amps in 2 seconds. This error occurs if there is a problem with the drive motor, thermal protector or motor controller. Over-loading the unit may cause this problem.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Washing machine pulls ca then c1 code. seems to be the calypso action problem. does it need a new motor
The C1 code signifies "Average current limit Or Instantaneous current limit."
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or C1 for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem. "
Please check down the drive motor to resolve the issue.
Have a blessed day!
Thanks!
mannu_rakesh
Sep 01, 2009 | Washing Machines
Kenmore elite calypro CA error code. Plus makes
The CA indicates that an average current limit on the drive motor has been exceeded (see images below). This is an extremely hard problem to diagnose and one that I've seen cause the best service techs to pull their hair out. It can be one of so many different components, and you have to catch conditions just right to have half a chance to discover which one it is.
Try removing some of the clothes; this could be caused by overloading. You could have a mechanical failure in the universal joint, wiring harness, the drive motor, central control, or the motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 21, 2009 | Kenmore Washing Machines
CA error code on Calypso Washer
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
May 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
1,104 people viewed this question
Dan Webster
Dan Webster
Sal De
