Question about Maytag Neptune FAV6800AW Top Load Washer
Stuck in the superwash mode
Maytag top loading neptune. Like the washer until is started having this gremlin.
Plug it not electrical, all lights on, spins cyclelights are sequnecing through all spin modes. When perssing Off button or any other nothing seems to work. All membrane do work, I was able to get into the sc (service mode) run the membrane test all appears to be fine.
Sometimes I can put clothes and detergent in machine, unplug it and plug it in, will start the superwash cycle.
  • 94 Answers
SOURCE: clothes still wet washing on Maytag neptune
Your pump, or the hose between the pump and drum, might be clogged.  Could be spare change from unemptied pockets.
Posted on Oct 17, 2007
SOURCE: maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Posted on Nov 12, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
tzweeb
  • 318 Answers
SOURCE: Maytag Neptune MAH5500BWW Will not spin
maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
Posted on Jan 06, 2009
dh1200s
  • 335 Answers
SOURCE: maytag neptune fav6800aww wont spin on rinse cycle
With this post I’m attempting to enhance the troubleshooting process regarding dc/UC errors in Spin Cycle associated with the FAV6800A machine. The troubleshooting steps are more to help DIY owners but it could be good info. for other owners to pass along to their appliance repair service if you go forward with a repair. I’m a DIY’er who refused to junk my machine as long as parts cost did not trigger a replacement decision and I have some basic mechanical skills. What I have learned about these fail codes, dc/UC in Spin Cycle is…. this is a chronic failure condition associated with the FAV6800A series machine (no brainer per numerous posts in this forum) and I feel that most of the time these codes are associated with a clutch malfunction.
The troubleshooting guide packed in the console of your machine makes reference to this issue in the Will Not Spin section of the guide and states to replace the clutch. I re-lubed my clutch with WD-40 and I have been working with 30+ loads of varying size with no Spin Cycle errors since early December 08. I and two other DIY forum members found this issue to be a maintenance issue with the clutch, no out of pocket cost for me and I’m sure under $5 for the other two forum members, I had a can of WD-40 in the house. See the links I have attached within this post. There is a description of the clutch removal I did in those posts. I hope this works for others; I’m sure many of these machines head to the curb for bulk trash pickup. Maybe you can extend the service life of your $1K machine if this proves to be a clutch re-lube fix for this issue. Shame on Maytag for not placing a quality sealed bearing in the clutch…. my opinion.
1. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 2...
2. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it will begin to rotate CCW. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction and the Spin Cycle will fail with dc/UC errors. If this is not the situation move on to step 3. I need to post step 3 and the rest of this post in a comment.
Posted on Jan 30, 2009
Why won't my maytag neptune front loading washer will not start?
Check out the door switch to make sure that it closes when you latch the front door. If it does not close the machine will be inoperative - safety measure.
Sep 19, 2017 | Maytag Neptune MAH5500B Front Load Washer
Hi - my maytag top loader FA5800AWW is stuck on wash cycle. it won't do the spin only and it is sometimes getting stuck locked.
I feel you have a Clutch issue Google this phrase ""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Repost on that site in the Maytag forum and I will help.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag (FAV6800AWW) top load washer. The cold water won't shut off except at the valve. The cycle will run properly with hot water but if you have the cold on it just runs until it...
the water valve is bad in the rear area inside the machine,its controlled by electrical solenoids and the valve is stuck open even with the unit shut off,replace the valve combo hot and cold as these dont repair
May 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl top load washer - the cold water continue to fill and over flood the tub.
Pull the washer 120VAC power cord. Does water continue to flow into the machine?
If yea you have a Stuck Open water valve. If know then you may have a stuck pressure switch.
Are you going to try to DIY the repair? Further troubleshooting will be required.
Apr 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My neptune washer is stuck in pause mode I can't set it any any wash mode to wash a load the start/pause light just keeps blinking. Is there any way to reset it or boot it to get it started again thanks...
Karen,
Power it down by pulling the 120VAC power cord to the washer then plug back in and see if it will progress with the wash cycle. Which machine do you own the FAV6800A LED console display or the FAB9800A LCD console.
If still no good I will have you try to get into Service Mode but let’s see if a power cycle will clear the issue…….Rich
You will need the Service Manual for reference. Sears Parts Direct for reference.
May 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Installing new washer and plug is stuck inside washer.
On this unit you will need to removed the shipping bolts before the plug will release. It is so important that these bolts be removed that the manufacture designed the plug to be stuck inside until all 4 bolts are properly removed.
The installation guide will have instruction on how to properly remove or post a comment to this if you have questions and I will do my best to address them.
Apr 21, 2010 | Maytag Neptune MAH6700A Front Load Washer
Maytag neptune front load washer says control lock and wont start and buttons wont work
unplug the washer for 15 minutes then:plug it back in and, restart a few times in a different cycle canceling each time until the door opens. Do this only if the tub is not full of water if it is let me know and, i'll show you how to drain the washer first before we try to open the door.
Jun 09, 2009 | Maytag Neptune MAH6700A Front Load Washer
Top load washer
1. Remove top. 2. remove left side lock accuator. 3. open accuator case. 4. Solder small broken wire back to diode. 4. reassemble 5. enjoy.
Oct 04, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washer: will not start
plug a light into the washer outlet to check for elec current at this point before anything else.
Aug 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune FAV6800AW Top Load Washer Logo
43 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
