Question about Plumbing
Water wells my friend has a clayton mark and it stopped running so he is trying to pull the 300ft. you have any tips on this for him? Thanks Tammy
    Champion:
  • 242 Answers
You should call a well digger company and or buy a new pump.
Posted on Sep 17, 2008
Repairing 3 leaky frost free Clayton Mark water hydrants?
No, you don't need to know how deep they are.
Usually the rubber tip called a plunger is all that needs to be replaced.
You'll need to know your model number or easier is to just bring the old one with you to the store.
On this page is an excellent diagram of a Clayton Hydrant.
Clayton Mark Yard Hydrants parts
Here is a video of how to take one apart.
Oct 03, 2016 | Washing Machines
Where is the radio fuse in a 2005 malibu & how is it labeled?
Hi Tammy, try this> The radio fuse is marked "Radio" and is a 10 amp fuse located in the Body Control Module which is on the passenger side front of the center console, where the passengers left foot would rest. The trim panel pulls off, and the BCM is behind it.
Feb 25, 2015 | Cars & Trucks
What do I do to stop water from leaking from the tank, it refills itself several times, day or night? The toilet looks like a Sedona, although the shape of the tank differs a bit, the width is the same,...
Sounds like something in the floating device is bad so it doesn't shut off when filled. We just replaced our flush valve on ours because the toilet keep running.
Jul 11, 2011 | Toto Toilets ST784S 12 Sedona Beige...
How to stop running water in tank
Replace the "Ball ****" ...it is non-repairable...it is the part that regulates the water level in the toilet tank...also check the "Flapper Valve", if it is worn it will cause the toilet to leak.
Please rate me
Dec 31, 2010 | Toto Toilets ST784S 12 Sedona Beige...
I have a whirlpool duet frontloader. Last week I noticed that it would stop in mid cycle and not finish. I would start the cycle over to finish the cycle and it worked a couple of times and now it will...
I believe you have a drain pump issue. Try removing the bottom front panel on your washer ,three small screws right at floor level. the drain pump will be right their in the middle up front.. lay down some towels or a pie pan to catch some water,remove the cap on the end of the drain pump. Clean out the cap/strainer and remove any visible gook in the pump,line up the marks on the cap and pump and reinstall..hopefully it was full of junk and your ok now, sometimes though the impeller in the pump gets damaged and it will run but not pump even if you have to replace its an easy fix Good Luck
Sep 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
After flushing water will not stop running it has a power gravity value in it
Bad flapper seal needs to be replaced or too much tension in the chain.
Nov 22, 2009 | Toto Toilets ST784S 12 Sedona Beige...
Clayton mark freeze proof hydrant
You are going to have to dig and replace the entire freezeless faucet. sounds like it either froze or rusted off.
Jan 22, 2009 | Halex Liquid Tight 90 Degree Elbow, 3/4"
Water Well
pls measure ur pump resistance also amperes during operation also measure supply voltage
Sep 15, 2008 | Plumbing
Machine leaks after my kid tried to run it with the water shut off
simple. the water inlet valve burnt out and more than likely melted. anyway it needs to be replaced.
Nov 08, 2006 | Maytag Neptune MAH7500WH Front Load Washer
Plumbing Logo
135 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
