Question about Cameras
I have a Kodak Easy Share Camera ANd I have a charger, had this for 2 years and now the charger shows green when charged but will not open the lense
Mine did the same thing and I found out that the battery door was not completely closing. I put a rubber band around it to put pressure on the little battery door and it worked. My son's camera did the same thing.
Posted on Sep 15, 2008
My dgcam was not charging,it was kodak easy share dgcam.
do you use usb charder? kodak camera has poor circuitry for power control unit. If it is just usb charger problem then you just buy external wall charger from Ebay..com. It is inexpensive then repair. Good Luck with you...
May 21, 2011 | Kodak EasyShare M530 Digital Camera
My kodack easy share c183 camera will not charge
The C182 isn't a battery charger. It uses standard AA batteries, disposable or rechargeable. If you use rechargeable batteries, you must charge them outside the camera using a standard battery charger.
Dec 26, 2010 | Kodak Easyshare C182 12MP Digital Camera
My sons kodak easy share will not come out of video mode. and my daughters easy share will not charge.
To enable us to determine how to assist you further please supply the following details:
2. Kodak Product model and serial number
10. Error numbers and messages
In regards to the charging problem: This problem solution is only if this is M or later V model camera
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
Oct 12, 2009 | Kodak EasyShare One Digital Camera
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
I have moister inside the lense of my kodak easy share dx6490. How do I open it so that I can dry the lense
Hello Steve, There is no easy way to open the camera,your best bet is to just let it set in a warm dry area for a couple of days.This usually occurs during times of high humidity or from a rapid change in camera temperature like warm indoors to cold outdoors.
Best Regards, Russell
Jun 12, 2009 | Kodak EasyShare DX6490 Digital Camera
Camera immediatly shuts off and lense goes back in.
Sounds to me that ist is more of a charger issue. Try to borrow another charger and see if that works or not.
Jun 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak easy share digital camera m863
I have a Easy Share M863 and have had it less than a year. It was working great and then last week I tried turning it on and it would not open. I thought it might be the battery needed charging so I did that. It still will not open. I contacted Kodak and they told me they would give me 15% on a new digital camera. That is not what I wanted. My camera is not even a year old. It should have lasted longer I think.
Jun 08, 2009 | Kodak EasyShare M863 Digital Camera
Kodak Easy Share M873 suddenly not working
What happened is that the camera got turned on in your pocket or somewhere and the lens got jammed trying to open up. The problem is that the outer lens ring is not turning all the way and the camera doesn't fully load.
Solution 1: Put the camera into the charger, press the power button so the green light is flashing, unplug it from the charger. The camera will try to realign its lens. (You might have to do this a few times.)
Solution 2: Manually help turn the outer lens ring clockwise when it turns on.
Oct 29, 2008 | Kodak EasyShare M873 Digital Camera
Kodak lense adaptor 49 to 55 mm
kodak z-612 , z-712 , use 52mm to 58mm adapter. a z-712 has threads they are had to see but there there.
Oct 28, 2008 | Kodak LENS ADAPTER 49 TO 55MM Lens...
Cameras Logo
54 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
