Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Spark plug Where can i find spark plug for this equipment. I have searched all over and I noticed there is a separate oil compartment. Could someone tell me if I am to put a certain type oil in the back side of trimmer
  • 50 Answers
You can obtain a spark plug at any Troy Built dealer. Lowes is ours. Your owners manual should tell you what type of oil to use. Again you can obtain it at Lowes.
Posted on Mar 28, 2009
Were is the oil screw
Search Results
    1. Remove the dipstick, if equipped. Tilt the mower deck with the air filter or spark plug side up, and position some newspaper and an oil pan or jug beneath the mower. Use a 3/8" drive socket wrench and extension (no socket) to turn the plug counter clockwise (see photo at right), allowing the old oil to drain.
      How to Change Oil ' Briggs & Stratton
      https://www.briggsandstratton.com/...mower.../how-to-cha... Briggs & Stratton
Oct 24, 2015 | Garden
Why is there oil under my briggs and stratton 4hp pressure washer motor? (on the top of the pump)
pressure washers are unique in the fact they have two separate compartments for lubricating oil , one compartment holds engine oil and the other compartment holds pump oil/coolant the two compartments should never mix (bad idea) even though they both take similar type oils , sometimes the pump oil chamber will expand a bit with heat in use and a little oil will pop out a vent hole in top of pump , this is normal but if this is too excess its an indicator of larger problems (blown seal) both compartments should be ck'd before use every time for both level and clarity and causes fixed for any thing that's noticed , pressure washer pumps are very expensive to repair , with costs in the hundreds to thousands of dollars for seemly minor repairs ( nothings minor on them) and the oil is there way to keep cool and work ok for years
Jul 05, 2014 | Briggs & Stratton Garden
Why does my tractor run fine for a few minutes then it starts sputtering and stalls out
it might need a valve adjustment. search for your engine model number and valve adjustment and you should find a video with instructions.
Jun 23, 2014 | Craftsman Garden
Have oil in the number one spark plug well
have someone , ( or you ) do a compression check on the motor,, that will tell you if you have a blown head gasket,, or a bad intake gasket , Hopefully its just a simple valve cover gasket that has a O ring for the spark plug seal , I couldn't tell by your question if the plug had oil on the top or on the base, so I gave you both things to check
Sep 08, 2011 | Saturn LS Cars & Trucks
Hi Please can you confirm what fuel the Ryobi rg6700k generator takes?
Hi. I've been looking online and there's no information about this model. However this is how to tell which fuel it uses. If it has a spark-plug it burns petrol. Diesel engines don't have spark-plugs they use glow plugs which are different. Spark-plugs have a spark gap which the spark jumps across while glow plugs do not.
If it has a separate place for putting oil, and a dipstick for checking the oil level, then the fuel is petrol only. If it doesn't have a place for oil then the fuel is petrol mixed with 2 stroke oil. I hope this answers your question.
Jan 19, 2011 | Garden
Have Miller 225 w/Kohler engine and can not get it to start. Have fuel all the way to carb, battery hot, new plugs, new fuel pump, but still will not start. Oil level is good. Got any suggestions?
Check to make sure your getting spark first... A new plug doesn't help if your getting no spark.. Harbor freight sells a spark plug tester for $5 and it plugs in between the spark plug wire and plug. It has a light in it so you can tell if your getting ignition!!
Dec 03, 2009 | Welding Tools
Where are the spark plugs???
Look in your engine compartment. Find where you fill the engine with oil, and look on the surface of the engine that it attaches to; you'll see the 4 coil packs for that side of the engine. You'll notice that each one has a large wire leading down to the side of the engine. Where this ends, is where the wire hooks up to the spark plug. The other 4 are on the opposite of the engine, exactly in the same place.
Nov 29, 2009 | 2003 Chevrolet Avalanche
Lost spark on a chinese 50cc scooter
Change the induction coil or change the spark-plug.
Aug 25, 2009 | 2005 Suzuki RM-Z 250
I have a tremendous amount of oil in spark plug compartment
You will need to replace valve cover gasket and pcv valve.
Jun 18, 2009 | 2002 Daewoo Lanos
I want todo a tune up myself
for a normal tune up, the only thing you can change are, fuel filter, oil filter and oil, cabin filters, transmission oil filter and trans oil, and spark plugs. The other (tune items) such as spark plug wires and points, and timing settings are either eliminated or non adjustable. If you have the equipment you can do a computer check, but if the truck is running well it probably won't tell you much.
May 19, 2009 | 2001 Ford Expedition
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
396 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
Dwain Pippen
Are you a Troy Garden Expert? Answer questions, earn points and help others
