Hotpoint WT960 Ultima - Error Code F08
I have a Hotpoint WT960 Ultima washing machine and have the error code F08 being displayed. Does anyone know what this means or how to fix it? I seem to be able to find info on every other error code except this one.
Thanks
  • biggysilly Jan 12, 2009
    I have the same problem did you fix yours?
  • Lesleyk Apr 18, 2009
    I have the same problem, any ideas, is it an engineer job? Any info would be a great help. Thanks
dazmaraz
  • 67 Answers
SOURCE: Hotpoint Ultima (WT960)
check filter first as the pressure system is connected to the filter
Posted on Jul 06, 2007
  • 5 Answers
SOURCE: Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
SOURCE: how do you remove the child lock off the washing machine
hold the child lock button down for a few seconds.
Posted on May 09, 2008
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint wt960 ultima, very noisey when on spin
Remove lower rear panel of washer, remove belt and spin drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then look elsewhere for prob..Could be noisy motor, or loose concrete balance wieght.
Please rate my solution.
Thanks.
Posted on Aug 27, 2009
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
My hotpoint washing machine wt960 keeps displaying the fault code f-08 when trying to do a 40 c wash
Error code F08 is indicating that the heater relay cannot be activated.
Check all connections on pressure switch----module---- and heater.element.
Hope this helps, this is the recommended procedure.
Dec 01, 2009 | Washing Machines
Screen display reads f-08
  1. Error code F08 indicates heater relay stuck
  2. Check pressure switch connections
  3. Check heater connections
  4. Check module connections.
  5. Check pump and or pump filter for blockage.
Please rate ,my solution.
Thanks.
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code F-08
The meaning of F08 is that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
In order to resolve this the only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Hoep this resolves your issue. God Bless.
Jul 09, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washing machine WF860 F-08 error, does anyone know how to fix this
F08 error code: for hot point washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
hope this helps
Sep 29, 2008 | Hotpoint Washing Machines
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
564 people viewed this question
Top Washing Machines Experts
