Question about Maytag Dryers
There is a klicking noice in the back of the dryer while it runs. Can that be eliminated?
Corsley dryer won't run has power to timer but the light won't come on when the door is opened and has no power to the motor
Posted on Sep 15, 2008
I have a kind of "klick klick klcik klick"
Weird noise or unusual sounds from within the engine must be looked on seriously . You need to check on take a second opinion as it can prevent serious damage and expensive work.
Sep 16, 2011 | Motorcycles
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
I have a Whirlpool Gas dryer LGR5620KQ1. The dryer spins but when I start it, it buzzes then clicks but no heat comes out. It only makes teh noice when I select the "heat" portion of the cycle. I...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Whirlpool Dryers
Dryer making rubbing noise like belt is weak, sprayed belt no change, tilled dryer forward noice stopped. ,also spayed with lubercate inside holes inside dryer noice stopped temporily
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 30, 2010 | Hotpoint NVL333GY Gas Dryer
Unusual squeak noice
easy way is a bit of furniture pollish on belt / fly wheel
Jul 23, 2010 | Kenmore 74602 Gas Dryer
Whirlpool Dryer- Model #YLEQ5000PW0, does not get hot enough to dry clothes and makes a ckicking noice when the drum rotates. What do you think the problem is?
if you have any heat than your element is good,the reason it take's so long to dry the clothe's is due to a blockage,first you nead to look behind the dryer with out moving it to see if the vent hose is pinched off,next try running the dryer with out the vent hose hooked up,if it dry's well than you have a blockage some were between were the vent hose hook's up to the dryer and vent outside.you nead to check the roller's for the clicking noice.
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
Hotpoint tuble dryer, Aquarius, VTD20 makes scraping sound
sounds like the back drum shaft has worn and dropped through back[plate ... there is a fix for this by buying a new drum shaft and support kit comes with front bearing also .. can be a tricky job tho ....
Mar 30, 2009 | Hotpoint NWXR473EV Dryer
LG Dryer, Makes a whistle noice
I am takeing it that this unit is still under guarentee if this is the case demand a replacement as they obviously can not solve the problem if the machine is under guarentee they must repair it and they have so far not been succesfull so demand they fix or replace before the guarentee runs out
Jan 26, 2009 | Dryers
Magic
Klicking is the gears. Klick Klick Klick is the machine skipping gear spots and trying to recover.
Needs new gears.
Could also be the main boards going bad since the board controls the brew drive and the gear system.
Its one of the two. If it is the board, saeco cannot fix it and they do not have replacements. They stopped carrying them about 6 months ago.
Mar 23, 2008 | Saeco Magic De Luxe Espresso Machine
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
