Question about Jenn-Air JCD2389G Side by Side Refrigerator
Dispensing unit doesn't work
We lost power for about 18 hours and when the power was restored, the dispensing unit would not work. There are no lights lit, including the dispenser light. Pushing the actuator pad does nothing.
    Champion:
  • 210 Answers
Could be the dispenser control board.
Posted on Sep 27, 2008
Ice maker only produces crushed ice no cubes
Good Afternoon Gerald, thank you for your post!
I see that your Frigidaire refrigerator is only dispensing crushed ice not cubed ice. Your solenoid (which tells the dispenser crushed or cubed) might be frozen. You can defrost the solenoid by disabling power from it for at least one hour and then restoring power. If you continue to experience this issue you may need to have the solenoid replaced or the control panel and I would suggest having a professional technician out for proper repairs. Good luck with your refrigerator! -Matt
Apr 16, 2016 | Frigidaire Refrigerators
Hi there...have the light continually flashing red...have cleaned it all out and everything is puched in etc...any ideas what it could be?
Had the same problem, switch off, take out the coffee dispensing unit. close everything else up, drip tray, dregs box and front door etc then re apply power. It'll clunk and whir a bit then stop. Switch off and refit the coffee dispensing unit making sure it fits flush with the rear of the housing (you can check this by looking through the hole where the dregs drawer fits. power up again and it'll clunk and whir again as it resets the dispensing unit. I hope you'll find that it's ok now.
Aug 05, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Side by Side Refrigerator ice/water dispenser computer problem
You either have a loose wire or you'll need a display board. The only other cheap thing that you can try is to unplug the unit and plug it back in. But if that doesn't work then it's one of two things. Are you sure that you don't have a extended warranty on this unit? Is this a GE unit?
Aug 12, 2009 | Refrigerators
The ice maker and water dispenser does not work. There is no power to the exterior dispensing unit on the refrigerator.
I'm assuming you are saying there is no ice and water being dispensed, but that the ice maker is producing ice.
Actual ice maker operation is independent of the fountain which is for dispensing only.
The power is checked at the fountain board on wires Red/Black and White. The door must be closed when doing this check as power goes through the door switch. If no power is present, check the same wires at the connector under the upper door hinge cover.
The next check would be Red/Black to Blue while depressing the actuator pad button.
Outputs off the board are Pink to auger motor, Black to fountain water valve, other Black to fountain light, Violet to cube solenoid, the two brown wires go to the ice chute door solenoid.
The ice maker can be checked by removing the plastic cover up front. Check test points L to N for 120VAC. Short test points T and H to cycle the ice maker. Make sure it does not have ice or water in the mold already, or it will run over.
Of course last but not least, check water to the refrigerator. It is a dual valve and unlikely both solenoids could fail at the same time.
May 04, 2009 | Jenn-Air JCD2295HES Side by Side...
Zojirushi electric dispensing pot
Got greasy white stuff floating inside the kettle, any idea where this comes from? And how to eliminate it besides getting a new one. This unit is over 5 years old. Thanks.
Oct 18, 2008 | Zojirushi 5L Water Dispensing Pot Cd LCC50...
AMANA refridgerator water dispenser not working. Freezer door not closed properly last night.
Hello schlucks
welcome to fixya.
You said, Your AMANA refridgerator water dispenser not working. Freezer door not closed properly last night.
When the door to the freezer was left open all night,the moisture from outside caused the water line to the water dispenser to freeze!
What you need to do is to move all the articles from your freezer to a spare or second freezer
temporarily.
Then turn off the freezer compartment of the first unit where the water is not depensing .
you will need 12 to 24 hours untill the line defrosts.
If the dispenser works sooner then don't wait any longer to restart the freezer.
In some models, the fact that the freezer is turned off may affect the power in the dispenser untill the freezer is turned back on.
After you finish defrosting and turn the freezer back on. give it 24 hours to get back to running temperture.
Then reload the articles agin.
BUT DO NOT TAKE 20 TRIPS TO BRING THE PACK AGES AND LOAD IT, LEAVING THE DOOR OPEN AGAIN!
Bring the articles to the freezer and load it straight awy quickly and close the door.
This will solve your problembarring any damage to the dispenser!t
Thank You for having me advice you.
Huuum
Please remember to leave a rating!
I'm sure you are solved!
Some info!!!!!!!!!!
cold air to the bin and make it colder.
Water and Ice Dispensers
(on some models)
Depending on your model, you may have one or more of the
following options: the ability to select either crushed or cubed
ice, a special light that turns on when you use the dispenser, or a
lock option to avoid unintentional dispensing.
NOTES:
■ The dispensing system will not operate when the freezer door
is open.
■ After connecting the refrigerator to a water source, flush the
water system. Use a sturdy container to depress and hold the
water dispenser lever for 5 seconds, then release it for
5 seconds. Repeat until water begins to flow. Once water
begins to flow, continue depressing and releasing the
dispenser lever (5 seconds on, 5 seconds off) for an
additional 2 minutes. This will flush air from the filter and
water dispensing system. Additional flushing may be required
in some households. As air is cleared from the system, water
may spurt out of the dispenser.
■ Allow 24 hours for the refrigerator to cool down and chill
water.
■ Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
Oct 03, 2008 | Amana Refrigerators
Low product light stays on
You can go to partselect.com and purchase a new switch for the low product. It mounts on the back of the dispensing rack, item number is 18 on the assembly diagram. It is also possible that the existing switch has become unplugged from the board by ice buildup.
Jan 25, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Dispensing problem w/attachment and maybe floor partion
The F5914 has a hose that must be attached to the pump when using the upholstry attachment. Make sure that the solution hose is pushed onto the pump valve all the way. Try pushing the hose down and then pushing the locking collar down to secure it. This will insure that the hose is fully engaged.
Jan 21, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
79 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
