Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water in bottom of fridge
I have a whirlpool refrigerator model ET1FTTXKQ02 and I have ice build up in the bottom of the freezer and water in the bottom of the fridge that eventually spills out onto the floor. If I take the ice out of the bottom of the freezer it is ok for a couple days the the cycle starts all over again. I have a Whirlpool refrigerator Model number ET8GHMXL005. IT IS ONLY 3 YEARS OLD. THERE IS WATER SITTING ON THE SHELVES IN THE REFRIGERATOR AND A LARGE AMOUNT OF WATER AND ICE UNDER THE PRODUCE DRAWERS IN THE BOTTOM. SOMETIMES THE WATER RUNS OUT ON TO THE FLOOR. WHAT IS WRONG? HOW DO I FIX IT?
  • 3 more comments
  • d-rec Sep 25, 2008
    water on the floor coming from the bottom of the refrigerator
  • fenderampeg Sep 28, 2008
    This is happening to me once again. How do I keep ice from building up? It is a real pain to have to take everything out of the freezer and fridge to drain the line
  • Anonymous Jan 16, 2009
    water bottom of refrigerator
  • holtmeier Jan 29, 2009
    Drain in freezer compartment gets frozen over. This creates an ice dam, that doesn't allow defrost water to go into pan under the refrigerator. I have tried alot of solutions that are posted. I made sure that after I cleared the drain line, water would flow into the pan. I believe there is a design problem with the aluminum catch tray that is suposed to funnel water to the drain hole. The water just stays in tray and developes the ice dam over the drain hole. Let me know if there is a fix for the standing water in the catch tray
  • phillypen Mar 27, 2009
    I have water from the defrost cycle building up in bottom of fridge that also splashes on to my shelves and into my bins, for this exact same model. I bought this fridge because I THOUGHT Whirlpool was the best!
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Posted on Jan 11, 2009
There is a lot of build up under the fridge whirlpool model ET1FTTXKQ02 we would like to know proper removal of parts and proper cleaning
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 20, 2011 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool gold refrigerator is not cooling ice build up in freezer. Water on bottom of refrigerator.
Too much build of ice in freezer will not cooled the refrigerator side, you need to defrost the fridge. Set it to proper temp setting, just enough to have ice on the freezer and also remove water on the bottom.
Thanks for asking.
Jun 24, 2011 | Whirlpool Refrigerators
Whirlpool refrigerator is not cooliing refrigerator half not sure evaporator fan working model et1mhkxmb08
If the fan is working, then there is likely ice build-up in the vent between fridge and freezer. If you remove the farthest rear panel in the freezer and then pull the venting in the fridge and clean out all the ice, then the air can flow to the fridge again. It is also recommended to keep coils and compressor free of dust and make sure the drain hose is allowing water to drain into the drip tray in the back bottom of the unit.
Jul 11, 2010 | Whirlpool Refrigerators
Water accumalating in the bottom of the fridge.
A common problem. All modern refrigerators have an automatic deicer. The heater kicks in, then MELTS the ice in build up in the freezer for a short period before freezing again. This water drains either in the fridge or out the back to the catch tray. Simply pull out the bottom drawers and clean the clogged drain hold where the water can drain and evaporate in the catch tray as it is designed to.
Mar 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a whirlpool Gold Model GR2SHKXKS01. My problem is ice build up under the bottom tray of freezer and when fridge defrost the tube is frozen solid and creates this build up. After cleaning all the ice...
I have Ice build up under the tray in the freezer which makes water run into my refig and makes a mess what would cause this is the evavorator motor out?
Jun 03, 2009 | Refrigerators
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
WATER pooling in bottom of fridge
did you try to remove the 2 ***** in freezer floor???. if not remove the floor and check for ice build up underthere, if so:
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 12, 2008 | Whirlpool ET8RHMXKQ Top Freezer...
THE DRIAN HOLE IS CLOGGED ITS IN FREZZOR IN THE BACK BEHIND THE BACK PANEL BUT YOU CAN LOOK UNDER THE FRIDGE AND FIND THE OTHER END OF THE DRIAN HOSE BLOW AIR TROUGH IT TO CLEAN IT OUT MAKE SURE THE FRIDG IS OFF FOR A DAY, OPEN FREEZOR DOOR TO MELT ICE IN DRIAN HOLE AND HOSE AIR PRESSOR MAY NOT BLOW THE ICE BLOCKAGE OUT DEFROST FOR A DAY THEN IT WILL CLEAN UP NICE
Aug 29, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
1,951 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
