Question about Samsung HL-R5078W 50" HDTV
Samsung HL-R5078W Lamp Fan
I have a Samsung HL-R5078W tv is great only the lamp fan on it is kinda loud wondering if theres something i can do to fix that
SOURCE: no sound or picture HL-R5067w samsung
alread change the lamp and fan did not work
Posted on Feb 09, 2008
electronick
  • 505 Answers
SOURCE: Samsung Dlp HL-R7178w not turning On.
If all 3 leds blink, it can be the lamp, ballast (lamp driver), color wheel, or dmd board (all are engine parts = engine failur). its usually the lamp, but you can listen to troubleshoot. when it turns on, you will hear the fans come up (humm..airflow noise), then you will hear the colorwheel (high pitched squeel.. it will come up to speed) and then the ballast will fire up the lamp.. if the lamp doesn't fire, you will hear the spark gap fire (a 1 second buzz noise indicating bad lamp).. the gap will fire 3 times, they tv will then retry again and again until it shuts off and kicks out the error. this power up path will help you listen to find your problem. i can assist further.
Posted on Jan 08, 2009
  • 1039 Answers
SOURCE: Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
Posted on May 02, 2009
asnowman
  • 788 Answers
SOURCE: installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 01, 2009
Mas Baz
  • 177 Answers
SOURCE: Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Posted on Mar 30, 2011
Testimonial: "THANKS "
My television stays on for about 2 mins thens shuts off
Possible:
Lamp about to fail (too dim and set will shut down).
Lamp Ballast failing (it drives the lamp)
Color wheel issue (usually there will be a high pitched or fan like sound heard but not always)---if wheel turns too slow set will detect that and turn lamp and set off.
May 16, 2012 | Samsung HL-R5078W 50" HDTV
hello Harley,
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
When I turn my tv on it makes this loud noise like a motor is running and I have no picture. Any ideas of what the problem may be??
hi,
you have to che check three thing in your tv
1. lamp
2. lamp cooling fan
3. color wheel
you have mentioned that there is a loud sound can caused by the lamp cooling fan or by the color wheel. when the bearing of any one get damaged it will create aloud noise.
check the color wheel first. also check the lamp is it broken or not. if you need any more assistance feel free to contact me through fixya
ok
Feb 02, 2011 | Samsung HL-R4667W Rear Projection...
My hlr 5078 wont turn on it gives me 3 blinking lights
CK the Lamp Fan if it stops running Lamp will shut off, and Ballast board is what turns Lamp ON
If Fan is OK Look at Ballast board it connects to Lamp Plugins. Encompass Parts Distrubtion List Parts/Prices for this TV 1-800-638-3328
Let me know if you need any more help.
Mar 21, 2010 | Samsung HL-R5078W 50" HDTV
Help please. Samsung DLP no picture just audio
Hi,Is your tv close to 6000-8000 hrs 2-4 yrs.If its it might be time to replace the lamp.Your part # is XL2200 Make sure you get the Philips lamp.There's other components that tend to go bad like the ballast which is the board that powers the lamp.When that is bad it will make continuous clicking noises or attempts to light up the lamp.But if you dont hear any of that then most likely its just the lamp that needs to be replaced.Have a blessed one!
Mar 01, 2010 | Samsung HL-R5078W 50" HDTV
No picture on my Samsung HL-R4667W TV.
Its your Lamp if you have sound and no picture.
CK the lamp Fan make sure it is running.
Lamps Prices depend on where you buy.$85.00 up to $300.00 Look on E-Bay under Electronics/ Lamp number-BP
Mats Electronics has them for $99.00
1-800-628-1118
remove your Lamp and look in middle of it,that will tell you if it is busted.
Feb 20, 2010 | Samsung HL-R4667W Rear Projection...
Samsung HL-R6768W started making squeal noise from rear of TV. At same time lost picture and will not come back on. Sound is ok and you can hear light trying to turn on. Can fan motor not working correctly...
Look at the fan and verify its comming from the fan and not the power supply unit, you can clean the fan or replace it, but yes the fan would be likly the problem. Make sure you double check the power supply unit and clean if its needed,
Rulds2008
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
Buzzing sound coming from colorwheel and not spinning as if something was holding it in place. after some reserch I ordered a new color wheel but the same problem so I tried 2 more thinking defictive but...
Sounds more like a lamp ballest. Listen for the sequence of events and please repost.
Upon powerup the fans come on, and the color wheel spins up. Once up to speed the lamp ballest is commanded to arc the bulb,(clicking sound) once lit the power supply just sustains the glow in the lamp.
Apr 01, 2009 | Samsung HL-R5078W 50" HDTV
Samsung HL-R5078W 50" HDTV Logo
147 people viewed this question
Henry  Thomas
Henry Thomas
