Gray faded look on top to picture
I have a gray/shaded field about 3 in. long across the top of my DLP TV screen. I replaced the bulb a few months ago and was wondering if it was the bulb or the way I mounted it.
  • 19,396 Answers
It can be the anty polarizing plastic screen that protects the display.
Often it causes grey or reddish shadows, in that case must be replaced.
Posted on Sep 15, 2008
Toshiba 62hm84 dlp
Sounds as though the system may have overheated. Do you regularly check the filters and clean them? An airduster can also help to blow dust out of hard to reach places.
Apr 14, 2014 | Office Equipment & Supplies
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
Sound no picture
Like stated before--May be another bad blub, especially if you used a generic or Neolux one. A phillips bulb WILL work right. Mits sets do NOT like generic bulbs !!
Apr 05, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
If the bulb is burned out will that cause no sound
sounds like screen gone tv repair man best bet have you got set on mute
Oct 24, 2017 | Mitsubishi WD65737 65" DLP TV
White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
Aug 20, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
It can be the plastic anti polarizing screen that covers the display.
Often it causes grey or red shadows on top of the picture.
Sep 15, 2008 | Toshiba 56H80 56" Rear Projection...
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
PROBLEM WITH SAMSUNG DLP TV
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Apr 07, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
