Question about Samsung CLP 300 Laser Printer
Images very magenta-y
All my imgaes seem completely over run with Magenta. I have cleaned everything possible, even cleaned out a whole load of excess magenta toner.
The black also seems to be fading on the left side - but maybe that's magenta related too... who knows... at my wits end. This just started out of no where
Plllease help
Thanks
Bron
  • kemp77 Sep 20, 2008
    I have also had this bizarre problem. It only happen with my CLP-300 when I choose a paper size that is not 'standard'. So if I change the page settings by even a cm (from A4 for example) it start to throw a load of magenta toner onto the page.
    A technician from Samsung came to look at and couldn't understand the problem . . . have had no joy and have resigned myself to printing only on standard sized paper (and eventually buying a new printer)
    Problem Solver:
  • 10 Answers
Possibility of low toner.
Not the magenta, but when every other color has run out, things do start seeming a little red.
Posted on Oct 02, 2008
Dell 7130CDN Chattering along with lines in color image.
Pay him
and let him fix with new items
you might end up destroying the whole machine
Jan 14, 2016 | Dell 7130cdn Printer
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
Excess cyan toner is on electrostatic transfer sheet even after wiping it. All black and white pages are printed with cyan background.I am even using original cartridges.
Since you have Cyan toner in places where it should not be then the only possible cause is a defective Cyan Toner cartridge. I worked on one just last week where the customer complained about Magenta toner on their prints. I also noticed Magenta toner on the Transfer Belt just as you see Cyan toner on the Transfer Belt. I replaced the Magenta Toner Cartridge and everything cleared up nicely. The Transfer Belt Unit can also cause similar problems but it would not be ONLY one color like Cyan. It would be a mixture of all colors. My bet is replace the Cyan toner and you will be fine. If you have an old empty one just shake it up a bit and try it as well. This might allow you to verify before buying a new cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 06, 2011 | HP Color LaserJet 2600n Printer
Photosmart C7180 - light magenta and magenta not printing. I've cleaned the heads and aligned the printer. The light magenta is printing when I did the 'Align Printer'. I also completed the 'Restore...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Dec 23, 2010 | HP Photosmart C7180 All-In-One InkJet...
Blotchy excess red toner left on side of page.
My first instinct would be to call the people who serviced it and have them check it out for you. If you don't have time for that then the next and slightly more expensive solution is to replace the magenta toner cartridge. My reasoning for this is if you get them to come out and explain that it is since they cleaned it then they can pay for the replacement cartridge, or clean it again. But I think that if the new cartridge does not solve the problem, then during the cleaning the tech made a magenta mess somewhere in the printer. I hope this helps.
Dec 05, 2008 | Kyocera Mita FS-C5016N Printer
Magenta streak running length of paper
Have you tried cleaning the corona wire?  You can also use a cotton swab and clean the drum.  Just be sure to unplug the unit from the wall and allow everything to cool down.
Nov 21, 2008 | Brother MFC-9420CN All-In-One Laser...
Dell 5100cn
deatech,
I am going to answer this even though there was no reply to my clarification report.
No, it is not a HVPS problem. This is a magenta developer problem. The magenta developer for some reason has the highest failure rate of all the developers, including black. Perhaps because there are more shades of magenta in color prints.
Since you changed the toner, we can assume you are not out of magenta, but it is possible that you did not run a developer cleaning in the maintenance mode on the magenta developer.
If the magenta toner had been allowed to run out all of the way, a developer cleaning would allow the toner auger to move fresh toner from the toner dispenser, through the feed tube, into the developer.
If you have run the developer cleaning, and you can see that there is magena toner on the magenta developer ( for clarification, the developers are located behind the imaging drum. remove the drum to expose the 4 developers ), then the developer itself is defective.
Good luck.
Cory
May 05, 2008 | Dell 5100cn Laser Printer
Black and magenta do not print
talk to your vendor.your printer might be in waranty
Apr 03, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Magenta colour comes through on all prints right across the page, it is faded but is still clearly there. I can temporarily fix problem by using the printer menu to clean the magenta developer, but it...
We have over 50 of these printers and a few have had the magenta bleeding problem. On everyone of them the problem was corrected by going to the clean developer function under Maintenence from the Menu and choosing to clean the magenta color. Usually have to run it a couple times but it has always corrected the problem so far.
Mar 29, 2008 | Dell 5100cn Laser Printer
Samsung CLP 300 Laser Printer Logo
61 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
