Question about Dell Axim X51v Pocket PC
X51v lost it's operating system
Help, guidance needed. My X51v had hassles with the battery latch lock and having read the blogs decided to open the case. I found the relative micro switch and snipped off the protruding plastic rocker part. I super glued the switch in the locked position and dropped a dab of two pack super epoxy in the recess of the switch (for permanence). I then turned the X51v upside down for the bond to cure. When fully cured I filed the epoxy so that the plastic slider lock rides over the reduced height of the micro switch. OK , reassemble the Axim, no hassles and turn it on…..this is where I start to lose it. On the screen is ‘SD Image Update A10_G3’……followed by ‘Update Failed’………Whooooa – wasn’t expecting that. I had expected a normal start and all would be sweet…….wrong! Now I quickly read a lot of tech stuff on the ‘AximSite’ and HTCGeeks’ sites, Eventually I downloaded a selection of ROM’s and sequentially tried them in an attempt to wake up my apparently dead X51v. I won’t itemize them but got three different results, ie (1.) ‘Reading SD card’ the bar slider froze at the halfway mark. (2.) ‘No Stable Image Found’ followed by ‘Update failed’ – ‘Image Updating Failed please try again’. (3.) This one goes all the way, as follows. ‘Image Updating’ > ‘reading SD card’ > ‘writing flash’ > ‘RAM checksum:0xBCF3A4F4 / CRC checksum:0xBCF3A4F4’ > ‘update completed’ > ‘image update finished please press power + reset to do hard reset manually’.  – I do this and get a blank screen, I then do a soft reset and get nothing Axim appears dead……..Apologies for the length of this help request, but any help would be very gratefully received from this seriously p….d off Brit geezer. (Prior to me molesting the machines internals, it worked perfectly; it’s about 2 years old). Afterthought’s; I’m guessing, but does the Ax need a resident operating system in place before the ROM can be updated. If my Ax lost it’s operating system when I opened the case (didn’t heavy hand anything – honest) there would be no resident O/S for me to update & is that why the ROM’s that completed the flash procedure didn’t work ???  - Do I now assume my Ax is in the same state of health as a certain Norwegian Blue ??
    Top Expert:
  • Dell Master
  • 40,710 Answers
Here is an example of what you did wrong
if the on button of a pc is faulty and stays in the on position rather that clicking back to the rest position , the pc will start then shut down as it you pressed and held the on button on
but fixing the micro switch in the on position you are turning it on then turning it off
best fix will be to get a new microswitch and realize that it is designed to do something and is not meant to be stuck up or modified
Posted on Feb 26, 2017
SOURCE: dell axim 51v
I have the same problem. Its from an over sensitive switch. You arent actually opening the battery case you are pressing against it. This triggers the switch and makes it think you are taking the battery latch off. I haven't actually tried it but you could open up the Axim and cut the cable going to that sensor/switch?
Posted on Mar 11, 2008
  • 3 Answers
SOURCE: reset button won't work
to wlumbria... hey listenup... if ur connecting ur pocket pc to the cradle it is not only used for the flow of data bt it also charges ur pocket pc... bt the chargin is quite slow  it will keep on showing  the red lite as compare to an charger it will charge fast and the red lite will turn green... so wht i suggest charge it with a charger not with a cradel if stil it doesnt wrk try changing the battery...!!!
Posted on Apr 06, 2009
  • 17 Answers
SOURCE: how to install windows mobile 6.5 on a dell axim
I'm starting the same thing myself. It looks complicated unless you do a lot of Pocket PC stuff. I've done a fair amount myself, but this is my 1st foray into the "cooked" ROM arena. Looks like Lenny's L14 is the best, it's wm6.5 for some technical reason I believe. MobilitySite.com has been an outstanding source of info for many of my undertakings & issues! AximSite Forum 1
Forum 2 has been rolled into MobilitySite and it was great too. Below are a few of the links I've been referring to.
Be AAAAAABSOLUTELY sure to backup your data!!! SPB backup has been great for our brood - it even lets you go cross device which you'll esentially be doing. Backup to a BLANK formatted SD card! The B/U is self extracting and very configurable both in and out. I lost a serious amount of stuff (life) when I restored & ActiveStink tried to sync my card with an empty database! My fault I'm sure, but still reeeeealy hurts. :(
Scared?? You should be, that shows you've got some common sense. Aside from data loss, you can brick your x51v if something goes wrong. That costs a bit to fix, I guess they have to physically go in and re-flash the ROM. Never tried it personally... ;)
As my good friend Miguel used to say, "GOO' LUCK FELLA!"
XcesvCmp
Cooking Downloads
Downloads (use Mega, it's faster than Rapid for me)
GOOGLE search
Posted on Oct 18, 2009
  • 17 Answers
SOURCE: Why do I get a battery latch open warning Axim x51v
There is a sensor on the latch that detects when it has opened. Over time, the sensor wears down. You can put a dab of glue on it (so that the button presses down even further) or fold a tiny piece of paper onto it. You can find the sensor right above where the latch is, after you've opened the back cover.
Posted on Nov 21, 2009
bahratt
  • 561 Answers
SOURCE: set password on my dell axim X51v pocket pc and forgot it
Once you forget the Password, your only option is to perform a Hard Reset on the device and reset back to Factory defaults. You data will be lost, as this is in place to protect you in case the device has been lost or stolen. If you have backups, or sync the device with Outlook, you can run a restore or re-sync the device to populate the data back into your device.
Hard Reset -
NOTICE: When you do a hard reset, you lose all the data stored in your device
Flash memory, and any programs that you installed on your device.
Do a hard reset if:
  • You want to restore the device to factory default settings.
  • You forget your password and need to reset it.
  • Your device is experiencing severe operational problems and you have already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you do a hard reset.
To do a hard reset:
  1. Press the Power button to turn the Axim unit On.
  2. Press and hold the Power button down while using the Axim stylus to press the Reset button at the same time.
  3. Release the Power button and the Reset button. The To clear all data in the memory screen appears.
  4. Press the Contacts button on the Axim to delete all of the data in the memory of the Axim handheld.
  5. Press the Mail button on the Axim to cancel the operation without losing data.
Posted on Jan 15, 2010
None of the doors open
The latches are "frozen" because of metal contracting in the latch or latch lubricant physically becoming more viscous or freezing and preventing movement of the latch. You may need to apply a sub-freezing lubricant to prevent them from freezing up in low temperatures. Best put the car into a garage and let the general higher temperature unfreeze the latches.
Feb 02, 2015 | 1995 Pontiac Bonneville
Tip
Dell PDA Battery Cover Warning Messages & Won't Power on
This is my 1st posting on this forum although I've done a lot of reading regarding the battery cover I think this is the correct solution.
To everyone that's having problems with the back plate battery cover warning messages or problems not booting up on your Dell PDA, I think I've found the answer, I have 2 Dell's PDA's, 1 a X51v & the other a X50v, I was having problems with both of them (1 had battery cover warning messages & the other had a screen freezing) so I stripped the 2 of them down when I had both rear shells together I noticed that the small piece of sponge that Dell fit to the latching mechanism one was on the far right of the latching plate on one & the other was in the middle of the plate, I looked to see which shell belong to which PDA & the one I was having problem with battery cover warning messages the sponge far right, so I swapped the back shells around & booted it up BINGO!!!!! problem solved, I'm fairly sure the SPONGE SHOULD BE IN THE MIDDLE OF THE LATCH PLATE, if I'm right Dell engineers & executives should be shoot, such a simple fix why didn't they let owners know about this. This has got to be easier than trying to bridge the switch contacts or rip the switch off the board, give it a go guys, Please let me know if it works on your PDA. I will upload some photo should any of you guys need.
welshcob
on Nov 26, 2013 | Dell Axim X51v Pocket PC
Dell axim x51v main battery low message. It has been ont he charger and I have the extended battery. How do I fix this?
Check to see that it is in fact charging. If the power button light stays amber and never goes green, it could be battery, PDA or charger. If you do get a green, that pretty rules out charger/cradle. If the extended battery isn't an ORIGINAL Dell, and is more than a year old, it's likely the battery. 2 quick checks: 1) Try a standard life battery. If you get exaclty the same result, your Dell's got issues. Might only need a firmware re flash. But if your going to do it, I recomend going to the LennySH WM6.1, it's faster, more stable, cool battery indicator & other goodies. 2)See if the battery is bulging; if it is, it's time is near. There seems to be a real problem with the eBay'ish extended batteries. On the other hand, I've heard a few guys report ok battery life, and just a low *reading*. Dell batts seem to give the best life, the aftermarket just doesn't have it together. If you dare, Lenny's 6.1 can be found on Mobilitysite, read up on it lot's if you decide to go that way.
Dec 23, 2009 | Dell Axim X51v Pocket PC
Sep 22, 2009 | Dell Axim X51v Pocket PC
I have a dell axim x51v, I does not stay operational
seems to be some problem with the battery itself. Try charging it fully and then check. Does the battery dip when the phone turns off?
Jul 08, 2009 | Dell Axim X51v Pocket PC
My dell axim x51v is frozen where says"tap the screen to set up...", nothing happen when tap screen , seems to be in locked position.  Problem started suddenly, after it was charging on craddle ,...
On the left side of the pda is a little slide button with a lock symbol on it, make sure it is slid down. This button is a key/screen lock to ensure you dont push any buttons accidentally.
Jun 11, 2009 | Dell Axim X51v Pocket PC
Battery latch
paper wedged in the sensor sometimes work. More extreme is 'surgically' removing the switch and connecting it up.... see aximsite.com for a guide.... otherwise take it to a technician.
Sep 19, 2008 | Dell Axim X51v Pocket PC
Dell axim 51v
Mar 06, 2008 | Dell Axim X51v Pocket PC
Dead - no response
Hi, I am looking for a battery related problem solution on my own Axim X51v, but it is different than yours. One thing I wanted to share with you is that I know if the battery cover lock button is not in the locked position (slid to the right) it activates the "battery door switch". I have occasionally received error messages on the Axim when I turn the screen on and it has missed sounding an alarm. it will say "the battery door switch was open, so the system was put into "sleep mode" to preserve data from being lost" or something like that. So I believe that the position of the latch is crucial. In my case, I think the switch gets dirty. When I get the warning, I slide the switch back and forth a few times and then it stops bugging me for sometimes several months.
So, if you do not have the cover on, then your latch is probably open, and the door switch will be sensed as open. I am not sure what Sleep Mode really does, but I'll bet it will make the Axim appear dead. At the very least, try sliding that latch back to the right. However, I would replace the door, because only friction actually holds the battery in place unless the door is on. It could fall out when you least expect it. Then I think you would lose any unsaved data, and if your internal backup battery was not up to the task, you could lose everything. I hope this info helps you out.
I'll go post my own problem now.
Oct 25, 2007 | Dell Axim X51v Pocket PC
Dell Axim x50v - Battery Latch Problem
Hi Guys
Here are some photo's of the before & after showing where the sponge will be when your Dell PDA is faulty (not booting up or battery latch warning messages & where it needs to be repositioned to, the photo's should be self explanatory, I used some double sided tape to refix the sponge but super glue might work but don't blame me if it runs into the latch mechanize & gluing it up for ever, this does really work & better than messing about with the PCB. I have posted more details on this forum just search for the title ""Why do I get a battery latch open warning Axim x51v"
Welshcob
Sep 09, 2007 | Dell Axim X50v Pocket PC
Dell Axim X51v Pocket PC Logo
271 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
