Question about Gateway Sb-4100-A PC Desktop
Can't get the door open to ad RAM
I have a gateway sb 4100-A PC and the black tab pulls back but will not release what am i doing wrong there are not circles to indented that i can find, please help
2 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: gateway sb-4100-b won't recognize new memory
REmove all the old memory and replace it by a new memory, you should test memory 1 by 1 .
first install the 1 memory in the first slot. then boot the computer using only 512mb. if this successful. shutdown and insert the second memory, then test again.
note: memory should be:
1. DDR SDRAM
2. the two 512 should be the same brand.
Posted on Dec 28, 2007
How to open and upgrade RAM memory of gateway netbook model LT2704u?
This netbook is really the Acer Aspire One D255. You have to pop off the keyboard, then remove 4 screws that hold the back panel in place, which will allow you to remove that back panel in order to get to the memory.
Here's a video - blurry but it tells the story: http://www.youtube.com/watch?v=6KYNTvF0-5M
A better video on removing he keyboard: http://www.youtube.com/watch?v=FoTwln2SyQ4
Mar 01, 2011 | Gateway Computers & Internet
I want to fit some extra memory to my Acer Aspire 9300. Which door do I open on the bottom of the notebook. thanks.
You can adding RAM to your Acer Laptop by following the below steps.
1 . Unplug your laptop from the AC power source and remove the battery.
2 . By unplugging the power connector you will be safe from shock.
3 . Locate the memory access door for the main memory module. It should be on the back of your computer.
4 . Unscrew the memory access door and remove it.
5 . Remove the RAM module by applying gentle outward pressure to the securing clips on either side of the RAM module until they release.
6 . Rotate the RAM module upward to a 45 degree angle and slide it out of the slot.
7 . Align the new RAM module with the tab in the connector slot.
8 . Slide it firmly into place and gently rotate it downward until it clicks into place.
9 . Replace the memory access door.
10 . Replace the battery and power up the computer. It should recognize the added memory and reconfigure itself for use.
Hope the above information will be helpful to you.
Thanks for using Fixya.
Nov 23, 2010 | Acer Aspire 9300 Notebook
Pulled out ''new'' 4100 from att box. trying to set up. want to get to 192.168.0.1 to set ppp location. but error message says it is interrupted? am also having att line troubles today. dave j
Push aand hold the reset button to get back to factory default. Some have a default gateway of 192.168.1.254. In your pc under start and in the run tab type [cmd] then [ipconfig] in the box that appears. this will tell you what the default gateway is
Jun 11, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
When turning on Sb-4100 I get message "unable to start driver for hpoipm07.exe". What to do?
Hi rbrown454. That file is for your HP printer. Go to hp.com and click on support and drivers and download the latest driver for your printer. While it's downloading go to add/remove programs in Control Panel and uninstall ALL HP software. Do not restart, wait for the software to finish downloading and restart. Then reinstall the software you downloaded from the internet.
In case you have the CD, reinstall the CD but make sure you uninstall ALL HP Software.
I hope this helps. Please do not forget to rate and provide positive feedback for our fast/free support today. Thank you :D
May 10, 2010 | Gateway Sb-4100-A PC Desktop
NO AUDIO ON MY SB-4100-A DESKTOP.
The reason to this problem is due to the audio driver.so you
need to install the audio driver.
Sep 02, 2009 | Gateway Sb-4100-A PC Desktop
Gateway e-4100 thermal event
There can also be thermal sensors in your power supply, on your motherboard, and video card. Does your problem happen during gaming/heavy computing, after x amount of time, or totally randomly?
If your case conforms to the later ATX spec or some derivative thereof, don't block the hole in the side of the case.
Just some stuff I've run into, maybe you already know this!
Nov 25, 2008 | Gateway Sb-4100-A PC Desktop
pull the black clip on the back up
then use the little indented circles on each side and press in and pull up
once inside switch three green tabs to show red.... then lift up the back metal base up and it will pull away from the RAM area
May 13, 2008 | Gateway Sb-4100-A PC Desktop
Gateway E4100 Mid Tower RAM install
no need to install RAM in pairs.
you can buy and install memory but it should be the same model that you have now e.g. DDRII RAM Modules.
you can max out the RAM 4 gigs
Mar 30, 2008 | Gateway Sb-4100-A PC Desktop
Gateway sb-4100-b won't recognize new memory
Check the owners manual of your computer for the correct installation of 2 sticks of memory, this can be critical on computers with 2 banks of 2 slots, it will also tell you the maximum ram that will work. If you do not have the manual, go to the manufactures website and then go to the support link, and browse for memory installation. BPCS
Dec 28, 2007 | Gateway Sb-4100-A PC Desktop
Gateway Sb-4100-A PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
