Question about Car Audio & Video
I HAVE A REMOTE STARTER/KEYLESS ENTRY . I NEED A REMOTE. IT DO NOT HAVE A NAME ON IT. JUST SERIAL# AND MODEL#
SERIAL# 152422 MODEL# RS623R
It is made by Accele. Google search for the company then give them a ring.
Posted on Nov 28, 2008
Sim number for Pontiac torrent remote?
2007-2009 Pontiac Torrent Keyless Entry Remote Key Fob ...
www.amazon.com/...Pontiac-Torrent.../B009E9LX5O
Amazon.com, Inc.
Rating: 5 - ‎4 reviews
Amazon.com: 2007-2009 Pontiac Torrent Keyless Entry Remote Key Fob With Free ... Manufacturer Part Number, Part #: 15913420, 20869056, 20952475 ...Missing: sim
2008 08 Pontiac Torrent Keyless Entry Remote - 4 Button ...
www.amazon.com/Pontiac-Torrent...Remote/.../B0068...
Amazon.com, Inc.
Amazon.com: 2008 08 Pontiac Torrent Keyless Entry Remote - 4 Button Models with ... GM Part Numbers: 20868672, 20952474, 15913421 w/ Remote Starter ...Missing: sim
2007 to 2009 Pontiac Torrent Factory Remote Transmitter ...
? 3:28
https://www.youtube.com/watch?v=OASrgxUXXdI
Nov 7, 2012 - Uploaded by Lessco Electronics
2007 to 2009 Pontiac Torrent Factory Remote Transmitter ... Press the set/reset button until REMOTE KEY ...Missing: sim
Jan 31, 2016 | Televison & Video
2008 HHR Remote Starter not working
Is this an issue with all 2008 HHR remotes??? Highly doubtful , probably the vehicles keyless entry system . Taking the vehicle to a qualified repair shop an having the keyless entry system checked for DTC'S - diagnostic trouble code's . Do you know what a DTC is ?
The keyless entry system is a vehicle entry device. The keyless entry system is used in conjunction with the body control module (BCM) to remotely activate certain vehicle features. Keyless entry will lock/unlock the doors, or release the rear compartment lid when a corresponding button on the keyless entry transmitter is pressed. This is accomplished by the transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a serial data message to the BCM. A low transmitter or vehicle battery or radio frequency (RF) interference from aftermarket devices, such as 2-way radios, power inverters, computers, etc., may cause a system malfunction. High RF traffic areas may also cause interference that could lead to a malfunction. Keyless entry allows you to operate the following components:
• Door locks
• Liftgate lock
• Remote rear doors (Panel only)
• Vehicle locator/panic alarm
• Illuminated entry lamps
• Remote vehicle start
The keyless entry system has the following components:
• Keyless entry transmitters
• Keyless entry antenna
• 2 Way Advanced Remote Start RCDLR
• BCM
Guessing will not fix this .
Jan 12, 2018 | 2006 Chevrolet HHR
Keyless entry does not unlock doors, open trunk, or start vehicle (remote start built onto keyless entry). Battery is new in BOTH remotes and neither one works. Could a fuse in vehicle be bad? Secondly,...
RFA / MOD fuse 10amp . location - insturment panel fuse box. Fuse Block - I/P
Right side of the I/P, behind the access panel
If the fuse is good your best bet would be to take it to a qualified repair shop , that doesn't mean the dealer . Lot of good independant repair shops around , just have to check the yellow pages.
Do you know what DTC'S are ? diagnostic trouble codes ! Not only the ones for the engine management system OBD 2 . There are also DTC'S for the remote keyless entry system , BCM - body control module. You need a factory or professional scan tool to view this codes
DTC B3101
DTC B3102
DTC B3103
DTC B3106
The remote control door lock receiver (RCDLR) communicates with the body control module (BCM) through the keyless entry serial data circuit. When any button on the keyless entry transmitter is pressed, the transmitter sends a signal to the RCDLR. The RCDLR sends a lock, unlock, or panic alarm request to the BCM, depending on which button is pressed on the transmitter. The BCM receives the message and performs the appropriate function. The BCM also uses the keyless entry serial data circuit in order to communicate with the RCDLR when programming transmitters. Do you know what serial data circuits are ?
DTC B3101 Keyless Entry Data Link Circuit Range/Performance
DTC B3102 Keyless Entry Data Link Circuit Low
DTC B3103 Keyless Entry Data Link Circuit High
DTC B3106 Keyless Entry Data Link Parity Error
This is what the factory manual said as to the location of power steering fluid reservoir ! Not much help , you would do better googling it.
The power steering fluid reservoir holds the power steering fluid and may be integral with the power steering pump or remotely located. The following locations are typical locations for the remote reservoir:
• Mounted to the front of the dash panel
• Mounted to the inner fender
• Mounted to a bracket on the engine
Aug 19, 2017 | 2005 Buick LaCrosse
MARS OMEGA# 343-02 FCC ID:M65NVT504 TRYING TO FIND OUT MAKE AND MODEL OF WHAT CAR THIS WAS INSTALLED IN. THANKS FOR YOUR HELP
This remote came with the MARS-22+. It is a universal type of keyless entry with remote start unit. It did not come with any particular vehicle, since it can be installed in almost any vehicle.
Dec 27, 2010 | Omega MARS-22 Remote Vehicle Starter with...
Bulldog m200 just stoped working
If it is the same brand and model you will not have to rewire anything
Jun 09, 2009 | Remote Starter with Keyless Entry
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
