Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Brush Bars won't turn
I have taken apart the brushes, cleaned the belts and brushes, and followed all instructions in the manual, and the bars still do not turn. Any ideas?
Terry
I borrowed a bissell 9500. It was filthy with the previous user's debris, including long and short black hairs, black goo from the swamps of hell, cat hair and dirt. I cleaned the whole machine (as mentioned in the online user's manual), pre-spotted my carpets, filled the appropriate fluid containers, and confidently turned power on to the 9500. The BRUSHES DIDN'T WORK ! After checking all belts, and other things mentioned in other solutions here on Fixya, I decided to check the trigger setup on the handle part of the cleaner. I unscrewed all the screws from the top of the handle down to the attachment holder ( there were seven screws). After that, I gently pried open the top portion of the handle in order to see down to the trigger. I gently pulled the trigger and, at the same time, repositioned it and the spring attached to it. Then, I put the screws back in, attached the power cord, turned on the power, released the handle's upright lock. When I did that, the brushes turned like they are supposed to. At that point, I felt like I'd awoken from a nightmare and, at the same time, been blessed by an unseen cosmic power. The rest is history. My carpets and upholstery are now as clean as when they were new. I hope this helps one or more of you out there with the "dead brushes" problem.
A solution submitted by:
Pierre Kunde
peter.kunde@gmail.com
Posted on Jan 30, 2011
Brush bar not working have taken it out and cleaned it
hi John.
you have not said on what model its not working.
but if you go to this link and look for your model it might help you out.
Brush bar not working Google Search
Nov 23, 2017 | Vacuums
Tip
Common generic problem with Dyson upright vacuum brush bar
I see lots of problems with Dyson vacuum cleaner brush bars not revolving, this is normally because the belt has broken, this is an easy and relatively cheap fix. Remove the sole plate normally held by a couple of quarter turn plastic connectors, once the sole plate has been removed the brush bar can be lifted out of it's slotted position, remove the remnants of the old belt. With the new belt manouvre it over the motor spindle first then position brush bar through belt and slot the brush back into its slots and reattach sole plate. This procedure should take no longer than ten minutes even for a total novice.
on Apr 16, 2010 | Vacuums
Vax Dual Power Pro W85-PP-T
If the belt is intact what about the motor, does it spin?
May 18, 2017 | Vax Vacuums
Beater bar
It could be your brush bar is not working properly if there is debris restricting the endcaps, the brush bar motor could be defective, it could be a switch or wiring problem.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Dyson 14 Animal seems to not have the suction
Hi its Darran at Dyson.
Firstly check that the brush bar control on the cleaner head is in the correct position. You may have switched the brush bar off the last time you used it or the dial may hav got knocked when you vacuumed under some low furniture.
If this is in the correct position but the brush bar is still not turning, switch the machine off and remove the soleplate by turning the 3 fasteners on the base of the machine and checking for blockages and remove any threads or hairs around the brush bar.
I would recommend washing the filter if it hasnt been done for a while.
You may find it useful to follow the blockage procedure and filter washing instructions in your user guide, however if you no longer have this available you download a replacement for free via the support section on our website at www.dyson.com.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Apr 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush roll won't turn
I think the belt has probably broken. These are easy to replace and you can access it by taking of the bottom section around the brush. If you do this you will see instantly if the belt is brokenm or not. Most electrical shops sell these belts-otherwise ebay do them
Jun 13, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brush isn't turning. Have cleaned around ends of brush. Looks like the motor isn't turning the belt.
Belt could be broken or has come off. It needs to be taken apart to find out. Not a hard fix usually. Since you didn't mention that it didn't squeal, got hot and smelled of burnt rubber or the roller didn't spin this is my guess.
May 09, 2009 | Vacuums
The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Vacuum - terrible loud noise
I have purchased six Dyson DC14 vacuums on eBay at rediculously low prices as they were being sold "as is" because they made a "terrible noise" when the brush bar was engaged. Each of the vacuums I received were like new, literally, and did make the terrible noise that was described. For less than $25 each, I purchased replacement beater bars (brushrolls) from an eBay seller in England and ALL six of the vacuums work perfectly.
When I dismanteld each of the units, some beater bars only had hairline cracks and and others were falling apart. I first purchased beater bars from eBay that were very cheaply made and broke within one or two weeks. The beater bars I got from England have been going strong in a commercial business for over a year now. That's equivalent to 5 years use in a residence.
Defective beater bars are more frequent than most people realize. I'd lay odds that is your problem but you will never know until the beater bar is removed and closely inspected. Some fractures of the plastic can be hard to see.
Hope this helps.
Mar 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
105 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
