Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
Hearing protection statement for use
18 volt 1/4 bit impact driver. Where can I find the additional safety rules for this tool?
  • 2,176 Answers
If this is a Dewalt tool as the picture indicates I would go to and type in your model number for a manual, I also believe there is an area that you can click on for this information
Posted on Jan 21, 2009
How do you insert a drill bit?
Grasp the ring at the nose of the drill. It has knurling around it. Pull it forwards and insert an impact rated driver bit or hex shank drillbit. Let the bit slide into the recess until it bottoms out. Release the knurled ring. You should hear the little keeper bearings spring back into place. Your toolbit should now be captive so you can go to work.
Apr 28, 2014 | Ryobi Impact Driver Kit: 18-Volt ONE...
How do you Insert a Ryobi One+ impact driver drill bit?
don't think there is much to it. See page 4 in this manual
Pull the chuck out to unlock it and push the drill bit and chut back in to lock it.
Hope this helps.
The chuck on the dewalt impact driver does not hold the bit holder in
If you go to you can enter your model number to see the parts breakdown. It can be tricky to get the retainer clip off and on but the rebuild of the bit holder is easy other than that. The spring and the steel ball are all that usually need to be repalced. Hope that helps.
Apr 20, 2014 | Dewalt DW056 18 Volt Cordless Impact...
How do i insert bit in cordless dewalt keyless hex chuck?
It only accepts 1/4" hex shank bits and nut drivers. Mine just pops in and to release it, you push the black collar around the bit down. Cannot put round end bits in it. Only hex shanks
Oct 26, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Have a screw head stuck in the chuck .. it was a small bit and now wont pull out.... help
Just took apart a DeWalt, the chuck has a left hand scew that holds chuck in place, may be the problem
Jan 20, 2011 | Dewalt DW056 18 Volt Cordless Impact...
How do i put a drill bit?
An impact driver won't work very well as a drill. In fact it will probably break drill bits in anything but very soft material (like drywall). A drill bit needs a smooth continuous motion, because it cuts continuously as it turns. An impact driver turns with a staccato motion.
Jan 19, 2011 | Dewalt DW056 18 Volt Cordless Impact...
My dw056 breaks bits can you change the hammer to a 1/4" or 3/8" hammer they look the same on the manual
in order to make the 1/4" hex drive impact drive 1/4" or 3/8" sockets, you need a 1/4" hex adapter for sockets.
They are available at most hardware stores. While i've broken several sockets, and many screwdriver bits, I've never had an issue with with the socket adapters.
You can also get an adapter that gives you a chuck like a conventional drill.
If you've been working them hard, it's not a bad idea to remove them, and put them back in. this reduces the chance of getting the bit stuck from the repeated impact.
As far as changing the chuck of the unit to another one, i'm not sure if it's possible.
Help me support children’s cancer research CLICK HERE!
Mar 08, 2010 | Dewalt DW056 18 Volt Cordless Impact...
02-03-09 Tues. 9:30am CST Hi Tech Help I have a DeWalt 1/4" Cordless Impact Driver DW056. It seems to slip when the trigger is engaged when loosening fasteners. I think the driver started impacting...
its supposed to impact immediately that is what gives the tool its power. once you get used to it you will use it for everything its lighter and more powerfull than the drill. just dont use spade bits in it or it will shatter them. try to buy tips that are impact ready
Feb 03, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DWo56 18 Volt cordless impact
all drill has brushes. this particular drill you need a motor assy
or switch. vibration & heat are common problem cu'z the drill not to properly
Mar 17, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
76 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
