Question about Maytag Neptune MAH5500B Front Load Washer
Lr code My serial number is 10794025ZB. Is the motor still in warranty? I have mold all over the gasket inside the door. Is there a fix or a recall on that?
  • 39 Answers
Hi gbailey1947
if your washe is under 10 year the motor should be under warranty, as far as the mold the only thing you can do is get it replaced. or spend a few hours with a tooth brush and bleach . if you get it replace i strongly suggest that you take the light out and keep the door open thsi will prevent any more mold.
brent
Posted on Sep 16, 2008
Samsung SLR550DW - replace the freezer door gasket
Hello Kev;
My name is Peter. I am a retired field service refrigeration technician.
The number that you have provided is your general manual number, which is common to several different models.
Your model number is on the upper inside wall, on a label in your fresh food section.
I have replace many a gasket. Post your model number and I will be glad to help you.
Dec 23, 2014 | Samsung Refrigerators
My Maytag washer will not complete a cycle. The code Lr is display on the front of the washer. I have pulled the plug and reset the breaker.
Hi.
LR stands for locked rotor. The code is returned by the Motor Control Unit (an electronic module connected to the motor and to central control unit). The code is returned when no motion from motor rotor is detected. With many models LR may be due to a factory defect. Please call Maytag and check if any recall has been issued for error LR concerning your washer model. If recall has been issued you will get a kit comprising a new motor and wiring harness.
You can also try temporarily resetting the error by disconnecting power at circuit breaker (or unplugging power cord). If the error message is prompted again call Maytag.
Regards.
Ginko
Aug 08, 2011 | Maytag Washing Machines
Maytag neptune tl what is code Lr
LR is the error code for Locked Rotor.
This could be an issue with the Motor Controller or Control Board.
I have not seen Drive Motor cause this issue to date.
If you want to investigate further I would suggest getting the FAV6800A/FAV9800A Service Manual.
Google this ""Neptune TL Washer FAV6800AWW""
This is a sticky for the FAV6800A/FAV9800A washer DIY support. Go to the 5th post down in the Sticky and you will find a link for the Service Manual.
If you want to go further in troubleshooting and possibly a DIY fix just open a new thread in that DIY forum with Model number and Serial number. That info is found tag behind the console right back side as you face the machine console.
Feb 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Plastic latch on left french door broken
Go to www.partselect.com put your model number in, click on the diagram. For the door. Should be part #PS1016086
/uploads/images/9_1_2014_3_03_11_am.png
Jan 30, 2011 | GE Profile PFS22SBSS Bottom Freezer French...
Maytag mah5500bww motor/control board failure recall
I had Maytag ship a new motor and motor control board for free and installed it myself in less than an hour. There is a ten year warranty on those parts. You just have to be very firm and insist you have warranty rights by law!
Feb 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
Amana refrigerator door gaskets not inflated and do not seal prop
you might need new door seal :
Refrigerator gasket Number: 67003548 70$ and see if it EZ to replace...good luck
Jan 01, 2010 | Amana ABB1927DE Bottom Freezer...
Wont complete the cycle reads Lr how do i unlock the door
maytag had many problems with this issue. "Lr" is a locked rotor in the motor. there is actually a motor control conversion kit maytag put out to fix this issue. And depending on the series number (first to numbers in the serial #) of your washer, there is a 10 year warranty for this kit. the kit is a new dc motor, motor control board, and harness. you should call maytag to see if you machine qualifies for this, the kits are expensive if you have to buy it. if you door wont unlock, and you need to get cloths out, open the lid for the detergent. look on the right side and the front inside where you put detergent in. you will see a green or red cord, that is the door lock release. if you pull on it, it will unlock the door, just dont pull to hard. good luck, shane
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Need repair kit for LR Code on Neptune Front Load Washer. Found it once a few months ago, but lost the printout and unable to locate the site again.
The part number for MAH5500 and MAH3000 is 12002039 you are going to want to bring your model and serial with you to where ever you buy it to confirm, but that part number is the most recent one, it contains the motor, motor control kit etc..which LR meaning locked rotor that would be the fix
May 01, 2008 | Washing Machines
Lr code
sometime resistor are a bit under valued and can burn up. Dont worry about your door lock. remember Lr stands for locked rotor.????? check the winding on your motor and never over look the pump. Have a visual inside the pump for blockage look for any shorts on your washing machine. I was told they have a ten year warranty on the motor. I always test all the conponents on a w/machine before I test it. lookup this site to see if your maytag is still under warranty???? maytag.com
Aug 15, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
98 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
