Question about Danze D500058BNT Parma Shower Trim Kit w/ 4" Showerhead - Brushed Nickel
Shaking of the valve D500058BNT Parma Shower, not the pipes
The valve start shaking sometimes when I mix hot and cold water, not with only hot, or cold, and you have to go back and forth with the handle to get the shaking.
  • Anonymous Mar 24, 2014
    mixing valve allows hot water only; as cold water is added, the water temp stays hot but the volume decreases. When valve turned to cold, no water flows.
  • 374 Answers
The issue you have is known as water hammer per se. It is the result of water logged air chambers in instances such as yours. The easiest solution is to turn off the water supply to the house and drain the entire system from the lowest point available such as a hose bibb/water spigot. Turn off your electric water heater if applicable as lack of water will burn out the elements. Once this is done turn the water supply back on to the house and bleed the excess air out of each appliance by turning it on and running both hot and cold water until air dissipates. Another cause may be an inadequately secured plumbing system behind the shower itself. The piping should be secured to some cross member to prevent movement caused by water pressure. A special device is made in extreme circumstances and larger systems called a water hammer arrester which does the same job as an air chamber but uses different principles to accomplish the task. I hope this is of assistance to you and thanks for using Fix Ya. If I can be of further assistance please let me know.
Posted on Oct 21, 2008
Is it possible to adjust shower mixer temperature?
Now my best guess is that you kept heater too high for a long time which means that the pipe carrying hot and cold water got touched and water became hot So turn off the heater for while and let the pipes cool off then turn the heater on at a low setting ...
Aug 30, 2014 | Rubinet Home
I do not have enough hot water from my shower head. I have plenty of hot water in my bathroom and kitchen sink. What can I do to remedy the problem?
the problem is the hot/cold mix is set wrong ---
remove the water control handle to expose the mix valve -- you should see a small set screw that will either increase or decrease the travel of the hot water valve. --- sometimes instead of a set screw there is a little pop off plastic set ring,, pop off and set to a more advanced travel.
this will increase the amount of hot water that flows to the shower head and the bath tap.
c...
Jan 20, 2011 | Grohe Freehander Adjustable Shower Head...
My Bristan Meridian Show start ok with hot water then after a few minutes the water runs cold. Even if you try and increase the temp it still remains cold. You can switch of the shower and start again...
It sounds like 1 of 2 things to me. I will start wit hot water heater. The first test for the water heater is to have someone run the hot water while you hold the hot and cold pipes and see if the water is coming out of the water heater cold when the shower goes cold. Of the water heater is cold coming out then the problem is in the heater. ether a lower element is bad or the dip tube is broken at the top of the tank. if the hot water heater continues to put out hot water when the shower goes cold then it has to be the mixing valve for the hot and cold mix at the shower and that valve will have to be repaired or replaced. hope this gives you a good start. let me know if I can help further.
Dec 24, 2010 | Home
Moen shower valve turns on full to cold water but flow becomes minimal when valve is turned to warm/hot. not getting enough warm water to shower. can this be fixed without rplacing the valve?
yes and no. Find hot water heater and insure cold water supply valve is open all the way. check to see if there is a hot water supply value and that its open all the way. If you replace shower value over iron pipe on the hot side it is corroded up replace pipe and value. If copper, find hot side, find value and open it up.
Nov 28, 2010 | Moen & One Handle Tub & Shower Faucet
Shower valve has a thumping sound when other faucets or toilets are turned on and off.when you turn shut offs to danze shower valve off sound goes away.could this possibly be the plunger in the valve?
Vfiippone,
I have the same issue with a Danze Sonora shower Valve. I called Daze and they sent me a new cartridge. After installing it I have the same problem. I also put a surge arrester on my toilet which had little effect. If you find the cure please post it.
Nov 04, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
No hot water coming through the shower system, though hot water comes through the pipe without system attached
When you adjust the dial to mix the hot and cold for your desired liking, it goes into a mixing chamber before going to the shower head, im asumming your issue is within the mixing chamber.
Nov 05, 2009 | Hansgrohe Shower 26101 Pharo Prestige...
Danze pressure balance single handle shower faucet (D500558BN) pipes vibrate when adjusting hot and cold water.
it the valve is full of dirt or needs to replaced not all the time but i have fix many buy just cleaning it out or pipes are fasten down. try just cleaning.
Jun 10, 2009 | Danze D500558BN Parma Shower w/ 4"...
Danze control valves producing loud water hammer
It sounds like your flow diverter isn't closing properly. Try removing the flow restrictors from the shower nozzle and see if that helps.
Apr 06, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Hudson Thermostatic Problem
try this.
if you have anti scald device installed in the valve, take it out. the anti-scald device is to keep the hot water from pouring out in case the cold water pipe is not functioning. In general sense, it is a good idea, however, it also mixes too much of cold water, therefore you don't get eough hot water.
Jan 10, 2009 | Home
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze D500058BNT Parma Shower Trim Kit w/ 4" Showerhead - Brushed Nickel Logo
418 people viewed this question
Top Danze Home Experts
 mstrmstr
mstrmstr
Mike
Rabbit Brains
Rabbit Brains
Are you a Danze Home Expert? Answer questions, earn points and help others
