Question about Kenmore Vacuums
Cant locate a manual for an old machine
I have a kenmore heavy duty home cleaning system from sears canada inc. it is a carpet cleaning system to shampoo rugs and furniture it is round (not an upright)model number is 175.85791C i hope someone can help
  • 40 Answers
SOURCE: directions for Bissell upright rug shampoo vacuum
Indeed, losing directions can be quite frustrating. Below, I did some research and found a website which has most Bissell Vacuum cleaner manuals and directions online
Hope this helps.
Posted on Mar 17, 2008
SOURCE: Bissell carpet cleaner
The spray hoses are bocked. The only way to clean them is to take the clear plastic cover off, un screw the base, lift cover, pull out red spray nosels, disconnect from main hose and wash under tap. Takes ages to do and is very fiddly.
Design fault as grit gets into spray holes.
Make sure you always clean machine after use,
Posted on Jul 26, 2008
need belt on brush
Posted on Sep 30, 2008
SOURCE: How to shampoo carpet...
Try Here:
Posted on Feb 28, 2009
  • 324 Answers
SOURCE: does my kirby come apart to where i can shampoo
YES there is Kirby upholstery shampoo attachment that comes in a standard set of attachments - HERE is the instructions. Try it on inconspicuous area first just to make sure that this is going to work on your upholstery. But I would just buy a can of upholstery foam. If you can not find it in a store - try automotive store - they definitely have it. Spray can is just much more simple. Still try it somewhere where you would not be afraid to damage the color first.
Using shampoo attachment on berber carpets is not as effective as on the regular carpet. Brush cant get to brush the fiber from all sides. You may have to shampoo berber rugs from several directions to get the better result.
Posted on Mar 21, 2009
How can I download Bissell Little Green Clean Machine manual?
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ... > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' > > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL® > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on ... (including all accessories and manuals) ...
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    • 4 MIN
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Need floor nozzle for Kenmore Home Cleaning system Model 175.8690090; no longer supported by Sears
    Unfortunately without seeing something like this it's difficult to know.Find a local vacuum store if there is one in your area. Take your old wand they should have something in stock to fit your wands. Internet is great to save a buck but nothing beats being able to walk in and put eyeballs on something like that.
    Good Luck!
    Aug 22, 2012 | Kenmore Vacuums
    Kenmore vac won't shut off, blowing heavy air from vent
    For the stack of problems you have, it sounds like it be best for you to ditch it and get a new vacuum. The heavy problem sounds like a motor issue. The burning smell is most likely from the belt being loose on the power head.
    Economically, you should just get a new one instead of replacing the whole system guts
    Aug 14, 2009 | Kenmore 25512/ 25513 Progressive Canister...
    The Dirt Sensor lights will not go out. It doesn't matter if I am vacuuming carpet or tile floor, the dirt sensors are all lite up. I can't locate my owners manual.
    Your machine could be clogged, check the tools for suction. If its a bag less model you might need to clean or replace your filters.
    Jun 29, 2009 | Kenmore Vacuums
    I cant get it to ****
    This is from the owners manual that I have provided a link to, so that you can have a copy for your records. I hope this helps.
    Possible Causes Remedies 1. ReadyTools dial may be at wrong setting. 1. Set ReadyTools dial to either FLOOR CLEANING or TOOLS setting. 2. Tank may not be seated properly. 2. Pick up both the 2-in-1 water tank and formula tank and reseat them so they fit snugly on the unit. 3. Tank may not be assembled properly. 3. Check to make sure the "lip" of the nozzle is securely hooked into the groove on bottom of Tank (see page 9). 4. Solution or 2-in-1 water tank is empty. 4. Check fluid levels in heavy duty bladder and formula tank. 5. 2-in-1 water tank has picked up 5. Empty 2-in-1 water tank. Refill maximum dirty water and red float heavy duty bladder with clean door has closed. hot tap water and replace. 6. Red float "door" in the tank may have closed 6. Turn the machine OFF ( O ), as a result of bumping an object or moving allowing red float door to release into machine back and forth too quickly. the open position. Turn unit back ON ( I ) to continue cleaning. Be sure your forward and backward strokes are done at a slower pace.
    Jan 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
    I have a Kenmore carpet cleaner 175-8690490. Can't find the instructions anywhere. Where can I find a user manual on line NOW? Thanks!
    For Sears, go to, click on the parts link, a parts list will come up and near the end of the list should be a owner manual that you can get thru them, that is if it available.
    Jan 08, 2009 | Vacuums
    Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
    It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
    Oct 26, 2008 | Kenmore 34612 Bagged Upright Vacuum
    Don't have a manual on how to convert the vacuum to the Carpet Cleaning System for the Kirby Ultimate G Diamond Edition.
    Generic problem for all Vacuums
    Posted by tamasnow on Jun 28, 2008
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best lace to get the owner’s manual for the Carpet Cleaning System for the Kirby Ultimate G Diamond Edition is to contact the Kirby factory cust serv dept and give them the model # and serial # is needed and they should be able to send out an owner’s manual for you as per the conversion t the carpet cleaning system. The phone # and the website address for further assistance. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Customer Service – U. S. & Canada 1-800-494-8586
    Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
    Mail To: Consumer Relations
    The Kirby Company
    1920 West 114 Street
    Cleveland, OH 44102
    Thanks, Don the Vac Man
    Go Ahead. Use Us.
    Jun 28, 2008 | Vacuums
    Vacuums Logo
    158 people viewed this question
    Top Kenmore Vacuums Experts
    Chris Nomland
    Chris Nomland
    Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
