Question about Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC
Dogz/Catz 5 compilation Vista Help
I've installed petz 5 on my comp that has windows vista. It seems to work fine but when I load up the program folder it doesn't have an adopted petz file or a returned petz file. I've tried making the file myself but it doesn't work as an adopted petz file. I can adopt petz but there is no file for me to use, especially if i wanted to download an adopted pet off the net, I would have no where to put it. Has anyone had this problem before? My friend has her compilation disc in her windows xp and it works just fine. Thanks for any solutions.
  • 5 more comments
  • Anonymous Nov 24, 2008
    the same has happened on my computer i hope someone can help.
  • Pufflezz Dec 04, 2008
    I have the same problem! I have many petz I NEED to download, but I can't.
  • MABVIEW Jan 12, 2009
    ME 2! And I'm starting a site! I need to acess them!
  • Anonymous Feb 11, 2009
    Same problem. I go to:
    Program files > Ubi Soft > Petz 5
    BUT THERE'S NO "adopted pets" OR "adopted petz" FOLDERS!
  • Anonymous Mar 09, 2009
    same thing...exactly
  • Petz5 May 24, 2009
    i have the smae problem as well but a bit different,
    like when i download a pet breed from somewhere like odd petz then i move it into my dogz folders in Computer>Program Files>Ubi Soft>Studio Mythos>Petz5>Resource>dogz,theres always an error.i dont know if it is because of windows vista or that there is a problem in the download...
  • Anonymous May 25, 2009
    Same thing, it's so irritating.
Firstly, open a folder. You need to click on 'Organize' >> 'Folder and Search Options'. On here click on the 'view' tab, then check the box for 'Show hidden files and folders'. Click OK on this.
Next go onto C: and click on your user name, then click on AppData.
In here, click on 'Local' >> 'VirtualStore' >> 'Program Files' >> 'Ubi Soft' >> 'Studio Mythos' >> 'Petz 5' >> 'Adopted Petz'.
Here is the file path if you need it:
C:\Users\Your User Name\AppData\Local\VirtualStore\Program Files\Ubi Soft\Studio Mythos\Petz 5\Adopted Petz
Hope this helps!
Jenn xo
Posted on Jan 12, 2009
As an alternative, you can install the program outside of the "Program Files" folder. Then it will behave just as it does in earlier versions of Windows. :)
Posted on Jan 28, 2009
PETZ 5 IS NOT COMPATIBLE WITH VISTA, THE VISTA SYSTEM IS VERY DIFFERENT TO XP!
Posted on Nov 25, 2008
  • 3 Answers
Yeah! My petz or working great!
I downloaded dogz 5 on my windows 7 laptop...but the graphics are messed up and the dogz have no faces..can this be fixed?
Try going to control panel then programs then choose run programs made for previous versions of windows
Jan 15, 2010 | Ubi Soft Petz: Dogz 5 and Catz 5...
Pets Don't Have Faces
Check that you are running in compatable mode. Since Windows 7 is so new not all programs run properly so you should have a link to run the program in a compatable stage. If not check and make sure your program is compatable with Windows 7. You may have to reinstall the program and you will probably get a message to install in a compatable mode. If you do make sure you install in that mode then the program should work. Windows 7 is like when they first came out with Windows Vista there are a few bugs that they are still working out and that is probably what is causing the problem.
Jan 10, 2010 | Ubi Soft Petz: Dogz 5 and Catz 5...
Petsz was working fine... in about a week .... it stoped working and thid came up while it was loading petz 5 has stopped working a problem caused the program to stop working correctly. Windows will close...
The only way to fix that problem (that i know of) is to uninstall Petz and click 'no' to i dont want to keep my petz.You will lose all of your petz.. but it doesnt wqork if you clikc yes so yeah.. Then install it again, and instead of using the game shortcut thats on ur desktop, go to My Computor, and click on Petz and play it from there.
Hope it works for you. :)
Jul 08, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
I'm using windows vista. petz 5 worked well at first but then suddenly i keep getting resource id = 1020 errors from the program, and it closes itself. what is this and what do i do?
Updates to the IIS metabase were aborted because IIS is either not installed or is disabled on this machine. To configure ASP.NUpdates to the IIS metabase were aborted because IIS is either not installed or is disabled on this machine. To configure ASP.NET to run in IIS please install or enable IIS and re-register ASP.NET using aspnet_regiis.exe /i. OR user@domain.com failed an operation on
Loading on to petz5, windows tells me program has a problem
Unistall, click 'no' to 'do you want to save your petz' You will lose all ur petz, but.. ts thw only way i know that works..
Reinstall, and play the game from My Computor, Petz. play. You will need to have ur disk in whenever you want to play.
Hope i helped
Apr 20, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
Distorted Dog in Dogz 5 Vista
I had the exact same problem and I searched everywhere on the net to try and find a problem with no avail. Then I thought of something and it fixed it!
Change your screen resolution to 1024x768
That's what fixed mine.
You can go higher. The maximum size I can get mine to before it gets distorted is 1360x768.
This is on Vista by the way.
I hope this helps.
Jan 01, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
Petz 5
Have you turned off any virus protection/spyware protection before you re-installed? Make sure the program is uninstalled in add/remove programs. Check for any spyware or viruses on the machine. Let me know what happens. Good Luck, Tim
Feb 23, 2007 | Ubi Soft Petz: Dogz 5 and Catz 5...
Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC Logo
2,615 people viewed this question
Top Ubi Soft Computers & Internet Experts
 Shayaan Tanwir
Shayaan Tanwir
Frank Zabroski
Frank Zabroski
Piyal Perera
Piyal Perera
Are you an Ubi Soft Computer and Internet Expert? Answer questions, earn points and help others
