SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor Check fan motor for continity IF none replace fan motor
SOURCE: Kenmore 106.53603202 stopped cooling making a clicking sound
It sounds like you have a burned out start relay on the compressor.
Pull the fridge out and remove the cover at the back. You will see the compressor. The relay plugs onto the compressor and the wires plug on to the relay.
Either the relay is burned out or the compressor is locked up. The only way to know for certain is to replace the relay. The relay is the problem on your model about 98% of the time. You can get one from any Whirlpool parts dealer for around $40, it will cost you around $280 for sears to replace it. The part number is 8201786.
Be sure you replace it with the correct replacement part, a fit-all or 3-in-1 start relay will work for a while but will damage your compressor over time.
Post back if you have any questions.
Mike
SOURCE: Flickering display panel on Whirlpool
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
SOURCE: how to remove the rear panel freezer
leave the unit off for a ewhole day with the door open. you are right that you may do damage when you pull off the cover. after the unit is defrosted there is sometimes coveres that you can pop off and behind them are the screws that have to be removed to check the drain out.g
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
