Question about Sharp LC-26D6U 26 in. LCD Television
Sharp TV Audio Problem
Audio sound comes and goes on my Sharp TV. Understand lots of people are having this problem. Does anyone know if it can be fixed at a electronics repair shop or is the repair to costly and I should replace a 2 yr old tv?
  • Anonymous Oct 10, 2008
    Rumor has it that there is a service bulletin from Sharp about the PC board needing replacement to prevent sound interruptions.  This cost about $350 parts and labor if you dont have a service plan.  I am not sure if this will fix the problems anyway ... since a new TV cost only $650  (I paid 2200 2 years ago!!!)  you might want to just buy a new set or upgrade to a better newer version.
  • jsrusso Feb 27, 2009
    LC-26D6U -- Audio went out after 35 months of use. Cost is $240 to fix at authorized Sharp repair in Philadelphia.
  • 16 Answers
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at avsforum.com/avs-vb/showthread.php?t=647174&page=13 for pics of the information detailed here.
Particular thanks are owed ‘Aureius’ of the AVS forums for his research efforts concerning this issue !
Posted on Jan 28, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Dryjoints on your speakers
Posted on Sep 22, 2008
    Problem Solver:
  • 8 Answers
Here is more info http://mans.io/brand/Sharp
Posted on May 12, 2015
Where can I find a service manual for SHARP LC40LE550U?
Try updating the firmware before repair /replace of parts.
I am sure you would have tried troubleshoot shown on page 38 of the user manual.
http://www.manualslib.com/manual/751149/Sharp-Lc-40le550u.html?page=40 Sharp LC 40LE550U Operation Manual Appendix Troubleshooting
Mar 02, 2016 | Sharp Televison & Video
Sharp Aquos LC-26D4U sound problem
Yes this is a common problem. You have to have it refered to a TV SHOP. I can fix it for you but in CA. the wiring on the speakers needs to be upgraded to a thicker wire. The gauge is to small for the current needed to flow evenly.
$75.00 Fix
Feb 13, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My sharp tv model 21V-W70M has no sound, the speaker is ok but no soumd coming out.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Check the voltage goes to audio amp circuit section.
Check speaker/s [If there is two speakers, both of it should be checked for coil continuity]
Check whether the audio is muted.
If all these are OK, check and replace the audio output IC.
Oct 02, 2015 | Sharp Televison & Video
I'm getting sound from my sharp tv when hook uo to my blu-ray player
If I understand when the blu-ray player is connected to the set you get the TV sound or what? If properly connected by way of a set of rear audio/video or component jacks to the same on the TV--you should if change the TV input to that location see the blu-ray and hear sound it sends out.
Component, composite, or what is the hook up between the two units?
Dec 05, 2012 | Sharp LC70LE640U 70-inch LED/ LCD TV
Hi Folks, I've got a sharp LC-26SA1E.The sound problem I have is that it only has 3 sound levels.None, Loud(30) and house shaking loud (60).There is an error code that has come up in the top left hand...
While tv is off press and hold buttons on tv VOL(-), A/V and switch it on, release buttons after 5sec.
Suppose to get back to normal state then.
I checked on my old sharp lcd lc-32ra1e and worked.
Oct 29, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
No sound from TV - Sharp TV LC-32GPIU
Check to make sure you have the speakers tuned on in the setup menu, and you are not in sap.
Sep 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Nov 10, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp LC-26D6U 26 in. LCD Television Logo
3,364 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
