Question about Rival Microwave Ovens
Hi I am looking for a rival deep fryer with auto shut off and it has to be big enough to fry french fries for four people.I live in Oshawa ontario canada and would like to know where to go by one or order on line.Could you please tell me. Thank you Mary Demerchant
    Champion:
  • 242 Answers
Walmart here's a good one Rival 4 Liter Deep Fryer CZF725
Posted on Sep 17, 2008
How do i freeze raw potatos for french fries
Cut into fries and then blanch and freeze.
Nov 08, 2015 | Microwave Ovens
Can you freeze raw potatoes and how do you do this?
i assume you want to pre-prepare chips for big family gathering? or for any period of time.
you need good freezing unit
potatoes
chips cutter
knife
3ltr (1 gallon) water with bit of salt and bit of vinegar in it
5kg (11lb) potatoes
table spoon
method:
water solution: to 3ltr (1 gallon) of water add and solve about 6 table spoon of salt and about same amount (6 table spoons) of vinegar (this solution will prevent blackening of the potato cuts), i am adding as well about 3 spoon of sugar to the solution, it allow liquid to cling better to the surface of potatoes, water should be cold, even few ice cubes in it will help
1. wash well your potatoes from debris, sand and whatever junk, remove unsightly, damaged or rotting bits from the potatoes
2. if you have chip machine or slicer - use it! chips should be not thicker than 12mm (1/2"), try not make them thinner than 3mm (1/8"), i do not bother with skinning them, but you may if you have masochistic tendencies. you can do that with knife as well, but will take longer. chips can be cut as straws, plates, sticks. waffle or whatever pattern you have in mind
3. chopped chips drop into the water solution and frequently stir as to allow all surfaces to be covered and prevent browning/blackening of the surfaces (this is oxidation of the surface, it is not poisonous but looks ugly)
4. after all potatoes were used, strain them from water, shake excess water and spread single layer on greaseproof (baking) paper or any other non-stick surface
5. your produce now need to be transferred to the deep freezer and frozen, minimum temperature should be -18c (0f), preffered will be -32c (-25f), if you are living in climate where these temperatures are outside, just put them outside...
6. after deep frozen (about 6h to 12h) divide them and pack them in sealed bags, in suitable portions
that way prepared chips can be stored for months, and if at lower temperature, even for years.
to fry:
have suitable fat at temperature of about 185c (365f), or whatever settings on your fryer is, you do not need defrost them, just directly from the fridge to the fryer, from the moment when they float, about 2min or until golden brown
enjoy!
if you like the recipy - why not vote for it?
Jan 01, 2015 | Microwave Ovens
Lights and fan not working on my microwave
was the fan working before you replaced the bulbs? Did you check the old bulbs ie filaments broken....if two bulbs stopped working at the same time probability suggests that the problem was not the bulbs, especially since the breaker fired when you put in new bulbs.
Could be a short inside ...if you are not brave enough to take it apart and inspect better you take to be looked at ...better a fried microwave than a fried you...
May 29, 2012 | Microwave Ovens
It is a rival 4.5l. the heating element does not work anymore. need to replace it.
If I read the title it say PROBLEM WITH THE MICROWAVE, on the other hand when I Google the Rival 4.5L it is a deep fryer?!?!?, now if you'r talking about a Microwave oven there is NO heating element, what produces the heat is called a MAGNETRON... it can be replaced but it's cheaper to buy a new oven. Now if you'r talking about a deep fryer, you are correct there is an element inside the unit but as for it's replacement you need to check if it is servicable, some models are riveted meaning you can not disasemble it without braking the rivets... if you finally get it appart check the element for a part number if it has one than it's just a matter of calling a near by applayance store and order it (it would be even better to show the element to the clirk) than again the element could cost as mutch as a new fryer...
Cheers!
Sep 03, 2011 | Microwave Ovens
I'm looking for a manual and drawings for the Lang deep Fat Fryer, type CLF-15-1 230 Volts, 60 hz
I am so glad I am able to help you -
Gary @ Fix Ya
Jul 11, 2011 | Microwave Ovens
Looking for a replacement cord for Philips deep fryer model 6161
Hi, you can get the replacement cord to your Philips deep fryer on this LINK..............
Apr 20, 2011 | Microwave Ovens
Ok we have a fry master natural gas fryer serial number 0401LP0001 model number BIH252CSD and we are trying to figure out if it has to be hooked up to a 220 plug or if we can use a 110?
look on the back of the fryer for an info sticker/plate that lists the specs for the unit...you'll see the voltage and phasing required for it...as an example, the picture below shows a 208V 3 phase unit...in general, i think 110V full size fryers would be rare if they exist at all...
Oct 16, 2010 | Microwave Ovens
I have as yet to get the right answer and help for what I have ask for. I received 2 answers for detachable cords 1. for a motercycle 2. for electric meters etc. I need a detachable cordset for an Ultrex...
Hi:
Don't know the specs on your cord, but you can try Aubuchon Hardware at 1-800-431-2712 they have a universal repl cord 6' long with 1and 1/16" pin spacing for $6.99 part # 652573,hope it helps, couldn't trace your cords model #...dan
Oct 05, 2009 | Microwave Ovens
PROBLEM WITH SHARP R-1874TF CONVECTION OVEN
sometimes an over heat will shut down the oven for a little bit but lets look at other things
i dont believe the board to be bad but i do believe the heating element inside is fried or a wire got fried by heat
if you know how to use ohm tester i would check heating element and wireing first
then try to see if the timer gave out
Dec 06, 2008 | Sharp R-1874 Convection/Microwave Oven
Microwave Ovens Logo
87 people viewed this question
Top Rival Microwave Ovens Experts
William Miller
William Miller
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Rival Microwave Oven Expert? Answer questions, earn points and help others
