Thank you for the direct question. The key word here is "tried". Your friend tried but he obviously done something wrong. I have used several power programers and have installed power chips on diesels and gasoline engines and only one has caused a problem, that was the "Jet" module on a Ford small block. If you know how to use them, they can and will change shift points, power bands, recalibrate your speedo per tire size and do other modifications.
I agree with the solution dms submitted, if there was a "learning stage" to go through, then the performance, towing and economy programs would have to go through them also. These aftermarket chips & programmers are all designed to plug & play.
I hope this helps.
Hi, Wait a week till things reset. If it still not working properly you can go to a mechanic. Good luck.
When installed correctly, there should not be a "week" for anything to reset. I never heard of waiting a week for any program that is modifying the electronic engine controls to correct itself. At this point, I'm guessing that your vehicle is running on set values that are not close to proper engine performance.
Contact superchip and they will tell you the same thing. They do not sell products that cause engines to stall or cause engines to run poorly, this happens when they are not installed correctly or something else is causing poor engine performance.
