Question about Refrigerators
LG Model 22711TT Fridge....Water/Ice Forms at base of freezer well,overflows then leaks
  • 126 Answers
TRY AND CHECK THAT THERE IS NOTHING BLOCKED IN THE DRAIN HOLE AS THAT CAN CAUSE IT TO OVERFLOW.YOU ALSO MIGHT NEED TO INSTALL A DRAIN PAD ELEMENT IF THE PROBLEM PERSISTS.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
My fridge is having a problem in the defrost. A sheet of ice forms on the base in the freezer and water is leaking into the fridge and accumulating on the shelves. It is a 2004 Whirlpool model...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 20, 2011 | Whirlpool Refrigerators
Top freezer forms ice
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
Jul 20, 2011 | Hotpoint Refrigerators
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Ice repeatedly forms at the bottom of the freezer compartment. Eventually it reaches the door and water leaks out. Signature Series Frostfree Model HMG51108
Your defrost drain line is frozen up.
Turn off fridge, remove bottom freezer drawers.
Remove visible ice.
Take a hair dryer and melt ice at the back of the freezer at the drain pan.
Pour a water and bleach mixture through drain hole.
This procedure could take a hour or more.
Feb 21, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
May 19, 2008 | Sub-Zero 632 / S
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Oct 28, 2007 | Refrigerators
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
