My 91 corolla screams when warm and accelaerating
If by "scream" you mean very annoying, high-pitched squeal coming from under the hood... it could be one or two things
It's likely that it's either a loose or bad drive belt. Check the tension on all of your belts by pushing down or pulling up on each belt. There should be some deflection...but very little. If you find a loose belt, simply adjust the tension, which is typically done by adjusting the alternator, and occasionally, another swivel mounted type component such as a compressor, or power steering pump. It's very important to make sure not to overtighten. If you push or pull on the belt and it barely moves, it's way too tight and needs to be loosened up.
In some instances, there is a spring-loaded idler tensioner, and it cannot be adjusted. If your belt isn't fitting properly with this type of tensioner, chances are it isn't routed properly, or you installed the wrong belt. There usually a diagram under the hood that shows how the belt should be properly routed. If belt is properly routed and still loose, chances are you have to replace the tension idler.
If all of your drive belts are in good shape, this last possibility isn't as common, but still can be quite noisy once it's going bad... the waterpump. You typically find this with older cars, because of corosion buildup over time, and bearings wearing out. In this case, you have to replace the water pump, along with gasket and sealant.
Hope this helps
