Question about Hotpoint TDC32 Electric Dryer
TDC 30 tumble dryer
Where is the heating element on the TDC30? The t/stats are at the back but I may as well replace the element at the same time.
Any help?
  • Hotpoint Master
  • 19,396 Answers
To test the heating element you need to access it by taking apart the back panel, and test it for continuity using a multimeter.
There are also a couple of fuses/circuit breakers that you should test.
Entering the model number here you get the exploded view, and replacement parts.
Posted on Sep 28, 2008
NO DRUM ACTION ON MY TDC30 BUT DO GET HEAT
When you start the dryer does it sound as if it is running but it does not tumble? Or does it make a humming noise?
If it sounds like it's running I'd check the belt first,
Humming noise and burning smell Dan indicate a bad motor or something stuck in blower wheel.
Oct 18, 2014 | Hotpoint Dryers
My beko tumble dryer is not heating up
Elements is generally behind the back panel, may not be an element fault but a tripped stat. If you're lucky the stat will be a self resetting one and not have to be replaced just reset. Always isolate from mains before removing any covers etc.
Apr 12, 2013 | Bosch Neff Beko Dryer 263297
I have a hotpoint tumble dryer model TDC30 and it is not drying the cloths. I have looked at the heating element which was broken so I replaced it. I have buzzed out the thermostats which seem to be fine....
If you are sure that the thermostats are both ok and the element has been replaced then the only other thing it can be is either a blockage or the timer that is at fault.
Hope this helps,
Jul 21, 2010 | Dryers
Dryer not heating...tumbles and blows OK - is 2 30 amp fuses enough
ELEMENT IS BAD NEED TO HAVE A SERVICE TECH REPLACE THE HEATING ELEMENT
May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Hotpoint Aquarius VTD 00 Tumble dryer no heat
Hi, it sounds like the reset stat gone on your vented drier. Remove the back cover, where the element is, and you should find two stats, one with a green spot. That's your reset stat. If you have a multimeter, turn it to buzzer and check the stat by touching the connections with the meter leads. If there's no buzzing, it's the reset stat. also check if the dark side of the stat is pushed inside. Remove the stat and hold it about 20inches from the floor. Drop it on the floor and the dark side will become flat. Repeat as many times as necessary. GUARANTEED TO WORK. Put everything back and that's it.
Cheers
Feb 14, 2009 | Hotpoint Dryers
TDC 30 tumble dryer
Your going to want to remove the back of your dryer. There should be a heating element housing back there. You may be able to see it by taking the top off to. It might not be your element that is causing the problem with your drying. You may have a bad thermal fuse. When you find the element turn on the dryer and as it runs watch the element. If it turns on and then off after just a few seconds then you have a problem with the thermal fuse. If it doesn't come on at all chances are the element needs to be replaced. Let me know if you have any other questions and good luck. Also, let me know if this was helpful to you please.
Jan 22, 2009 | Dryers
Creda Reversair Sensa Dry Tumble Dryer produces no heat.
There is only 1 heater element, and normally one thermostat.
they are located at the rear of the m/c, behind a removable panel.
If you are not sure whether it is the element or stat, join the two
wires togeher that go to the stat, if the heater then works, replace stat. if no heat, replace heater.
plz leave feed back for this solution.
Thanks.
Dec 17, 2008 | Dryers
Zanussi tc7103w tumble dryer not generating heat
There is a thermostat inside the drum if you open the door and feel up the front you will feel a disc with 2 screws holding it in remove the screws to expose the stat pull the stat out there will be 2 wires attatched to it. If you have a ohm meter check for continuity across the 2 conections or If you connect those 2 wires together and try the machine it should heat if so you will need to replace that stat. If still no heat i would suspect the heater to have failed
Nov 23, 2008 | Zanussi TC7114W Electric Dryer
WHITE kNIGHT tUMBLE DRIER THAT STILL TUMBLES WITH NO HEAT
there is an overheat resettable stat on the back under a small red cover. try for a start pressing the centre of the red cover and you should hear a click and dryer will then heat. this is the most common fault - get back to me if somethinbg different
Sep 05, 2008 | Dryers
Candy Nova CDC 266 tumble dryer. The tumble dryer tumbles but I have no heat and the filter light stays on constantly. Any ideas of what it could be?
hi ya this is the thermostat at the back of machine external,take the fan housing of it is nomaly the top one .beware change like for like do not exceed the temp rating of the stat.
hope you solve it
andy bird www.shropdive.co.uk
May 05, 2008 | Dryers
Hotpoint TDC32 Electric Dryer Logo
313 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
