Question about Compaq Presario 700 470024-192 Notebook
My laptop is dead
I thought the power charger was bad, but after buying a new one it still won't turn on. Any suggestions? My laptop is 8 months old.
    Genius:
  • 2,028 Answers
Let me start by saying; you should have absolutely no trouble with this laptop, as it's only 8 months old, not even a power supply problem. This is most likely going to be a problem with the power management system on the motherboard, and this could be a serious problem. I recommend using the warranty to have it fixed, and if possible, have it replaced, because you will most likely run into more problems down the road.
Posted on Sep 15, 2008
CHARGER NOT CHARGING BATTERY ON SAMSUNG N130 NETBOOK
Have you check the charger, is it providing proper voltage? it could be because charger if it is not supplying proper voltage to your laptop, if not then there use to a charging IC attach with the mother boardhas gone bad.
Aug 08, 2012 | Samsung Computers & Internet
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Sony laptop dead problem
Could be many things. Let start with a couple of easy ones.1) Unplug charger from computer and outlet, take battery out press power for at least 30 sec. Plug every thing back power on. 2) charger bad won't turn on or charge battery, try diferent charger if don' know how to use a voltmeter. 3) power jack loose or broken. 4) last and worst mother board circuits transitors etc... btw processor, video card or input devices fried. Buy new board from ebay. Don,t fix it. Not worth it. This is Only if laptop gives completely sign of not turning at all. No lights, no hardrive or no working or fan. No signal of life. If couple of lights do turn on it can be the ram or video card, play with ram a bit. Good luck.
Dec 09, 2011 | Computers & Internet
Dell Inspiron 1525 battery problems.
try removing the battery and turn on your laptop, then while laptop is on, slide in the battery.
Apr 18, 2010 | Dell Inspiron 1525 Laptop
My c500 presario won't charge and i think it's the charger. But when my battery went dead other times and i try to turn it on the lightning bolt indicator would always blink for a few secs. But now it just...
You probaly have a broken DC JACK on the motherboard. Therefore, regardless if you have a good power adapter. The power is not making a connetion to the battery because the DC JACK throught which the power flows is broken.
Try another adapter and remove the battery. If the computer is powered up using the new adapter then the old adapter is bad and the DC JACK is good. Replace the battery and if the batter charges, you can identify the old power adapter as the culprit. If the batter does not charge but the laptop powered on. Then both the battery and the charger is faulty-battery not holding charge.
Good luck
Sep 27, 2009 | HP Compaq Presario C500t Notebook
Gateway laptop not charging
Sorry, but unless you know someone who can fix that kind of thing, you will probably have to take it in (or try ityourself and risk the laptop's life). If the battery is dead then replace it; if it is burning it may be because the charger is providing more power than the laptop can provide. Check the product number on the charger to verify it is the one you should use. If it is, then I would think about googling the product number and try to buy a new one at Amazon or something. Hope this helps.
Aug 12, 2009 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
