Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Replacing the electical cord on Kenmore Progressive Vacuum
The cord is frayed where it comes out of the vacuum near the handle. It' always been very warm while vacuuming. I can replace it if I knew how to remove the plastic housing where the cord enters the machine. Can you help?
    Novelist:
  • 97 Answers
To the right of where the cord comes out of the machine is a large screw. Remove it, and slide the upper handle assembly free.
Then, on the front of the machine, remove the screws located toward the top of the vacuum just inside the bag chamber cover. This will allow the front panel to be removed, giving you access to the cord from the front.
-R
Posted on Sep 15, 2008
How do I take the handle apart on my Kenmore Progressive vacuum model 116.21614011? I removed the screws but it won't come apart.
There are catches that snap the handle together. It's hard to separate the handle without breaking the catches. Replacement may be required
Oct 05, 2013 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Progressive Vacuum-Need to replace plug
Splice a new plug, but get a good one. Tough with a scew to hold it together
  • White wire goes on the silver terminal.
  • Black wire goes on the gold terminal.
  • Green (or bare ground) wire goes on the green terminal
More here:http://www.hammerzone.com/archives/elect/accessories/ext_cord/end1/replace.htm
Mar 26, 2009 | Kenmore 25812 / 25813 Progressive Bagged...
I have a Kenmore progressive cannister vacuum cleaner.
There should be a pile height pedal on rear of the attachment, just behind the where the wand goes into it, near the handle release pedal. Just keep clicking on it to go through the height settings.
Please rate if this helps :)
Mar 05, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Replacing Power Cord Kenmore Progressive Upright
That actually sounds correct, if it's the model I'm thinking of. As long as you're talking about connecting to the wires that are held in by the wire nuts you should be good to go.
-R
Oct 25, 2008 | Kenmore 23613 Progressive PowerMate Bagged...
Kenmore/Sears Progressive 116 How to get housing off to replace cord
There are four screws, two at the front and two at the back under the step bar that rewinds the cord.  It lifts off from the bottom.  Be careful not to snap off the tabs.
Sep 20, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Power cord
May need to break the unit down to replace the cord,there should be some tec screws under the belt cover to remove the motor housing cover, may be two to thee wires. the rest should be simple.
Jan 09, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Dec 10, 2007 | Vacuums
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
351 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
