Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television Logo
Posted on Sep 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I fix the red doubling by adjusting the red screen screw now the people are greenish. can someone help me. pt-56wx53g
Sonny Berry
Level 3:
  • Panasonic Master 8,617 Answers
  • Posted on Sep 15, 2011
Sonny Berry
Panasonic Master
Level 3:
Answers
8617
Questions
Helped
1723418
Points
23750
Turning the red Screen down even slightly will make the other two CRTs dominate over red. You may be able to turn the Green and the Blue down slightly to balance them back to what red is at. Turning the screens down too low will cause them to shut off if they get lower than the cut off point.
I FIX my doubling red problem now the people are greenish someone help me.
Hi, To reset TV unplug for 1 hour. If this does not work try menu settings and change the color.
Also in settings set color to (cold) this may fix it. Good luck.
Model # pt-56wx53g my tv has extra red writing the picture looks like 3d. i need to know what part i need to fix it. plus a manual.
Thats a convergence issue. The panasonic PT53WX53 convergence repair kit from www.tvrepairworld.com is the correct kit for your model. The kit does contain instructions.
My panasonic pt-56wx53g projection tv from 2003, shut off and the red light flashes 3 times every 10 seconds. [email protected]
The 3 flashes is the error code for failed convergence. The Panasonic PT53WX53 Convergence repair kit fits your model. Its available at www.tvrepairworld.com the kit contains the ICs, Resistors and the CD with step by step repair instructions.
4helpful
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
2helpful
PT-47WXC43G green convergence no longer in alignment...
you can get the following repair kit at the following link. which contains the parts and the CD which has the instructions on how to do the repair. The kit you need is called the PT-53WX53G, PT-56WX53G, PT-
47WX53G, PT-47wx33G, PT-47WXC43G
and PT4743G. Convergence repair kit its at the following link.
http://www.tvrepairworld.com/
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aadjusting screen colors
They should be adjusted to set voltages. however it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels. Hope this helps.
1helpful
Samsung 52" rear projection tv convergence problem?
THE PROBLEM IN YOUR TV. IT'S THE CONVERGENCE. YOU NEED REPLACE THE CONVERGENCE STK'S AND AFTER THAT YOU NEED DO ADJUSTMENTS.
Panasonic PT-47WX49 47
Requires replacement of convergence IC's....STK392-110
Adjustments will not fix...................T.
2answers
Projection Tv Problem
some of these tvs have internal adjustments for everything including alignment which fixes the double image problem. if you remove the cover you will find a lot of little adjustment dials. you may find that they have symbols that show what the adjustment is for. if you want more info. email me at [email protected]
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
