Comment by Babylooch, posted on Feb 02, 2008
LeadTech,
I had the same problem as Arynsunn and Dorito. I was able to find and replace fusible link F231 and it worked for 2.5 days. Today, turned the tv on and the fuse must have blown again. We want to replace the convergence IC's, but cannot find them. Other posts show big (2 x 3") IC's on the back of heat sinks, but there is nothing that looks like that in our tv. Can you point us to the convergence IC's in this TV (RCA R52WM24)? Thanks so much for your help.
[email protected]
THe rca itc222 chasis has No convergence ics it uses a series of transistors to do the same. YOU replaced the Fl231 fuse and it blew. Did you resolder flyback connections. this is why the fuses blow. check out the article under the tips and tricks section written by me willtab ... see if this helps if not let me know .. i see alot of these at the shop ( i got one right now in front of me with the FL231 probelem LOL) if can let me know i give you help
