We have a acer lap topand trying to set it up wireless to our bt hub and it keeps saying on the lap top that there is not interent connection any advice
    Sergeant:
  • 305 Answers
Generally, to set up an initial wireless set up, you have to be connected to the web via a wired connection. this is only to set your setting preferences etc, etc. after that yopu should be able to go wireless
Posted on Sep 15, 2008
How can I recover the password for my bt homehub 2
This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
How to enable WI-FI function on Compaq Presario 2500 lap top.
Go to "network connections"
It should say Local Area Network and Wireless network (if your card is installed properly). Right click the Wireless Network and make sure it is enabled. Then click "View Available Wireless Networks" and choose your network.
If you are trying to setup a secure wireless network, that may be a completely different issue.
Jan 27, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Cannot install D-Link router
1. check your wireless adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Nov 24, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
You may try typing admin on the username field. Just leave the password field empty.
Once you're in the setup page, click on WIRELESS tab which on the left side of the page. On the Wireless page, you will see the wireless settings set in the router. You may also enable the wireless security on that page if there is not security enabled yet.
Please check this for your reference http://support.dlink.com/Emulators/di524/h_wireless.html
Hope this helps!
Nov 12, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless G Desktop Card Connection to BTHome Wireless Router
uninstall the bt desk top help first then the bt wireless connection , if ur wireless card has an utility use it to configure . the connection might be due the conflict between the wireless software. checked if ur getting limited or no connectivty if so delte and recreate  the wireless profile, if ur using bt router like home hub or voyager go the router page with the ip for hub its 192.168.1.245 and navigate to advance and keep the wireless channel to 9 or 11  for voyager the its 193.168.1.1
Oct 21, 2008 | Belkin 802.11g Wireless Desktop Network...
Msi pr 600 laptop (wireless problem)
Hi ppl
The problem was sorted out by my M8, he had the same problem!!!!
On the top right hand side of the laptop there are 4 buttons the one with the sat dish on it needs to be pressed between blue tooth & Internet. (Rember to switch) Hold button down for couple of seconds....
MMmmm sorted how simple was that?
thanks Andy
Aug 05, 2008 | Computers & Internet
Wireless connection problem
BT is right, the fault is at your end, because you can connect to the Internet with an ethernet cable.
You have lost your wireless connection with the wireless hub.
This could be low signal strength (especially if the wireless access point is in one part of the house and your laptop is in another room)
OR Your laptop wireless card has lost its wireless access configuration.
Check your laptop wireless configuration, check your signal strength, check your SSID, check your security (WEP or WAP),
Have you got MAC address filtering.
Go to control panel, click on network connections, right click on Wireless Network, Click on repair (might fix your connection problem), Else right click on Status (should give you indication of how your wireless is functioning or not functioning).
Check your TCP/IP settings is set for "Obtain an IP address automatically"
Without more information it is difficult to identify exactly what is wrong with your connection.
May 11, 2008 | Acer Aspire 5100 Notebook
Ive got a 40gb ps3 and a bt home hub wireless router how do i connect ps3 to computer ps ps3 is upstairs and pc downstairs
look on the back of your home hub. there should be a Wireless Key in a Grey box. (BT Home Hub wireless settings)
note the wireless key.
go to your ps3. and turn it on log on ect. go to settings and down to network settings (right at bottom).
(Im not sure of the next section because im currently on a network but it should be an option to find network).
anyway you search for networks. should find your home hub.
keep going right untill you have to enter any settings. and write your WEP Key (Not WKA). (wireless key from back of router).
Jan 10, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
