Get a 0809 error. This is on a OCE 7056 Copier
4 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: OCE 7056 Toner Not Fusing To Paper
you need parts to fix the heater. the heater is the part that fuse the ink to the paper.
since part of print is not fused to the paper. I am assuming at this time it must have multiple heater in the machine.
go to the link and see if they can sell you the heater you need.
www.kyoceramita.co.nz/files/1/Parts%20List%20v0405.xls
good luck on finding parts.
Posted on Oct 17, 2008
SOURCE: How do I fix a 0501 error on a OCE 7051 copier
check toner densety sensor
Posted on Jul 06, 2009
  • 3230 Answers
SOURCE: 0501 error with Oce' 7056
Well, error 0501 is low toner concentration problem
fill new toner and then off and on main switch many time, if the problem persists then you need to check the toner motor.
Good Luck!!
Posted on Jul 24, 2009
  • 149 Answers
SOURCE: Oce 7056 error code 0501
something has gone wrong with the developer/toner section. Call for service, these are not user fixable.
Posted on Oct 05, 2010
Hi, oce 3165 machine is giving error 1104,kindly help me get a solution to this
Output OP paper rejection roller drive malfunction.Try to reset the malfunction code to Open/close the front door.If not reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn On the copier.
Keep pressed the Utility key and wait while Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier ,wait 1 minutes and turn ON.
Apr 19, 2013 | OCE 3140 Copier
Oct 01, 2010 | OCE Office Equipment & Supplies
What is a error m1104 on my Oce 31x 5e
From what I gather from Oce' this is a "Master Cylinder Error". It's an internal issue that a tech needs to come out repair. Attempting the repair yourself (if you are looking at doing it yourself) will actually void your service contract with them.
Jun 03, 2010 | OCE 3140 Copier
What does E805 mean?
Hello :
Code error E805 in OCE copier means that you have to change the web cloth .
please rate !
Apr 12, 2010 | OCE 3140 Copier
I have an imagistics copier zc55 and I'm getting an error code C-12C6 when I start it up. Where can I get information on what this is.
Turn the copier off and on. If the error comes back, there is a problem with the image processing board. Call Oce for service 1 800 243 5556
Oct 08, 2009 | OCE Office Equipment & Supplies
What is error code 06112 ?
oce is a variety of different model of copier send me the picture of your copier then i can tell what model is it and what is the real problem low_toner@yahoo.com
Aug 06, 2009 | OCE Office Equipment & Supplies
Good Luck!!
Jun 04, 2009 | OCE 3140 Copier
Oce7050/error code 2205
what is oce 9400 error code 0813 ?
plase help me??
msmSAS@YAHOO.COM
Dec 20, 2008 | OCE 3140 Copier
Oct 16, 2008 | Office Equipment & Supplies
78 people viewed this question
k24674
