Question about Philips 32PF5321 32 in. HD-Ready LCD Television
Television hi telly gone off havent got a remote for tv using sky remote,got tv on and its coming up different langauges press ok but i dont know how to do it with the sky remote
    Problem Solver:
  • 14 Answers
You can press both volume buttons on the set to bring up the televisions menu. From there you can use channel and volume buttons to navigate the menu.
Posted on Sep 15, 2008
I turn on tv. There is sound but no video.
hi, if you have a device plugged into the telly that gives you the picture such as sky or cable then the best thing to do is disconnect this device from the back of your telly then switch the telly and this device off at the mains, then re-fit all the cables making sure they are connected properly then switch it all on.
now check if you have sound also make sure the tells is on the correct input for that decice and also make sure the mute button has not been pressed on the telly remote or on the remote of the device you use to watch telly, if after doing all that it still dont work then the chances are something has blown on the amp in the telly.
make sure you double check all the leads going into the telly to rule out a faulty lead causing you the problems
Jul 13, 2010 | Televison & Video
I need a list of codes to reprogram a universal remote for magnavox televisions.
hi, please could you let me know the make and model number of your remote, this may be written under where the battery goes as each model will have a different setup option.
if you do have the manual but dont have the codes then what you can do is an auto scan where you keep pressing the standby button until the telly turns off you then save it at that point then the remote should work the telly, if you dont have manual then let me know ok
i need to know if its made by ge or rct etc as their are a few people who make them
CLICK HERE
you may find the manual or codes here
here is the guide for an rca universal remote follow these instructions to scan through all the codes on the remote and save it when you come to the correct one, this is for rca how ever their are many other universal remotes so this may or may not work
1 turn on the target device, in your case this will be the telly
2 press and hold code search until the led lights light up
3 release the code search button
4 press and release the component button you wish to program in your case this will be tv it should flash then light back up and remain lit
5 press and hold the code search button until your tv tuns off then let go and press enter to save the code.
now if your remote is and rca one then keep doing this until the telly turns off then press enter and you should then be able to control the telly with the remote, if how ever this is not the instructions for your remote then let me know what make the remote is ok.
let me know how you get on or if you need further assistance ok
May 26, 2010 | Televison & Video
SKY DIGIBOX 2nd RF frequency
your in luck, I work for sky as an Engineer.
Firstly go to the main telly where your sky box is.
Using the sky remote press the following buttons.
SERVICES
0,1,SELECT
go to RF
In this menu I would set the RF channel to 38 and turn the power ON and then down to save.
now leave it on the blue menu screen (sky menu)
go to the other room where you link from your sky box is connected to.
press the tv button on that remote and then select channel 6 on the remote
Then go into the menu for the tv and then to setup. go to MANUAL TUNE/SEARCH with most new tv you can scroll down to were it says C _ _ you can then input your channel number as 38 the same as you setup on your sky box.
Dont forget to save the settings and that should be you. You should be able to see the sky menu on the telly with the link on. (that is why I asked you to leave the sky menu on that way you know you havent just tuned it into your normal terrestrial channels.
The reason I told you to turn the power onto the link was so that you can purchase a Magic eye. This will allow you to turn your sky box over from the 2nd room without having to keeping going to the main tv to change over.
here is a link to a random site with a picture of a magic eye on. you can purchase these from many places or even Ebay. here is the link anyway.
http://www.aerialshack.com/commtel-digital-link-magic-p-815.html
hope this sort you out. If so please leave a thumbs up
Cheers Little Dish Fitter
Sep 26, 2009 | Televison & Video
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Can't find a code for my ver 6 sky remote for LG50PS3000 TV
on your remote:
TV,
red + select (blinks twice)
TV,
0056,
press VOLUME button if this does not work press TV then repeat
once the VOLUME button works your telly press the SELECT button (stores the code).
If this does not work its because you have a rev 6 remote. take the cover off the battery case and it will tell you the rev number.
I install sky day in day out and ive only had one LG telly that did not accept this 0056 LG manufactor code.
The HD rev 8 remote will work no problem if you follow my steps..
Hope this Helps
Little Dish Fitter
Sep 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
HDMI conneection wont override tv picture
I am a sky engineer (not a subby)
the reason this does not come on straight away is because a Scart lead send power upto your telly when it is turned on. Telling the telly that this is what you want.
Unfortunately HDMI does not send power upto the telly. There are ways around this. ON Samsung, Panasonic and Lg tellys you can go into a secret menu and apply something called HOTEL MODE this allows you to change the av input so it would automatically come on your hdmi 1,2,3, etc
In your case follow my instructions below
go to the hdmi you are using for your Hd
on the sky remote
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice. what this mean is when you press your Sky button, tv guide, services or interactive button to turn the sky on this will automatically change your av/source on your telly to the sky HD for you
You owe me a pint
Have a good one
Little Dish Fitter
Jul 19, 2009 | Microsoft Xbox 360 Console
Code for 32 in lg tv to work with sky control
TV
RED + SELECT
TV
0056
try the power button if this switches off your telly press select to save the code if not repeat TV and then Power until it does... remember to press select once it knocks your telly into standby.
if you have not joy with this then you are going to have to get a newer sky remote. if you take the battery cover off the back of the remote you will see a sticker on there saying REV 4,6,8 the higher the number the newer the remote. then do the process again.
0056 is the manufacturers code for LG
Cheers
Little Dish Fitter
Mar 09, 2009 | LG 32LG30 32 in. LCD HDTV
BLANK TV
hi, what you need to do is find the source button or av button on your remote control as it sounds like its changed source this causing your problem. As you probably know your telly has many inputs for dvd vcr cable or sky but these plug into one of the inputs in the back of telly. Usually the problem is just that your on the wrong input channel like av1 instead of av2 or rgb their are many inputs so you might need to press this button 2 or 3 times till you get the right channel, i dont mean 1 to 9 channels i mean input channel like rf input or av input. This depends on what your getting the signal from if its cable and its plugged in via scart lead then it will be an av input but you might have av1 av2 av3 av4 this depends on your telly.
If your still having problems then give me a shout back ok best to check all the leads are in the telly correct as this will cause the problem your having ok.
Let me know how you get on ok or if you need further help
May 14, 2008 | Philips 32PFL5322D Television
Wiring diagram for sony kdl-23s2010
i can tell you the best way but i need to know what your using ie scart leads things like that also tell me how many scart sockets in telly and in dvd and sky and vcr after you give me this info il tell you what needs pluggging into what
basing it on your telly has 2 scart if not let me know ok
1. dvd to telly via scart lead
2. then sky to vcr via scart doing it this way allows you to record sky using av channel on vcr
3. vcr to telly via scart lead
then if you want your video to record normal telly channels you need to use normal arial leads in this order
1. from arial to vcr then from vcr to telly doin this allows you to record the channels you get through the arial like 1 2 3 4 5 also this way when you choose 1 or 2 or 3 on video it will record that channel allowing you to watch whatever on sky whilst recording normal telly
If your telly only has one scart socket in the back then you need to buy a scart adaptor that converts one scart socket into 2 or even
let me know if you understand what im telling you or if you need further help ok just let me know im going out for 2 hours but will check your reply then so hope you dont mind waiting if you need help ok
Feb 18, 2008 | Televison & Video
Philips 32PF5321 32 in. HD-Ready LCD Television Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
