My GBC Shredmaster 2260X is jammed and I can not clear it. The teeth try to rotate when stimulated but something is jamming it. Where can I go for service? I am in murfreesboro, TN.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
You can do it yourself!! it take a little bit of time and patience. do it in an area that you can clean easily. take off and unplug the top, turn upside down, get a flat screw driver and start removing all the papers in the teeth area. from time to time you will need to put it bank and turn it on and make it go forward and reverse.
Posted on Sep 16, 2008
Why won't my shredder come on?
Plugged into socket? Paper jam? Bad switch?
Feb 26, 2015 | Swingline GBC ShredMaster GLX2030 Jam Free...
I have a GBC Shredmaster 2260X. The light on top is blinking that means that the cabinet front foor is not shut. When the front door is shut. I have tried everything I can think of. And it wont work...
most GBX shredders have a magnetic "reed" type switch inside the shredder head that is actuated by a magnet on your door. have you recently lost the magnetic catch on your door? if you have lost it and have access to a strong magnet, you should be able to open door and move magnet around on front side of shredder head and see the light go out. if magnetic catch is on door, then perhaps your door is misaligned in such a way as to not energize the switch.
good luck,
razors
Jan 10, 2011 | Quartet gbc Shredmaster 2260X...
GBD Shredmaster Model 2260X about one year old...door close switch was intermittent and now does not show "closed" at all even when the switch is deflected. Is the problem likely to be in the switch or on...
If blowing some canned air into the switch doesn't cure the problem, the switch will have to be replaced.
Try Radio Shack or an electronic supply store.
Also, check the door alignment screws.
Sep 28, 2009 | Quartet gbc ShredMaster 2260X Cross-Cut...
Paper shredder does not rotate in either direction
You most likely have a paper jam in the unit. Check rollers and also check gears in the motors at edges or machine. Leave unplugged while doing this and an hour or to later to reset machine's memory
Aug 20, 2009 | Office Equipment & Supplies
DISCONNECTED WIRE
I clipped all the zip ties to free up the harness and physically inspected every connector till I found a connector that seemed rather loose and came off with minimal force. I then gathered the 3 wires and install a #18 wiring nut. the shredder is fully functional again.
Jun 03, 2009 | Quartet gbc GBC 10-Sheet Cross-Cut...
How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
Hello, I have a GBC Shredmaster 6120S
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc board has gone bad and you will have to contact your manufacturer for further parts availability.
Oct 02, 2007 | Office Equipment & Supplies
94 people viewed this question
k24674
jasbo
jasbo
