Question about Lexmark Office Equipment & Supplies
I'm un able to get my printer or fax working can u give me step by step direction?
My printer will not print. First the yellow toner light came on. I replaced the toner cartridge and moved the green lever associated with the corona lever. It still will not print.
Posted on Sep 15, 2008
Printer Says that it is idle and will not print
i will give the right solution , but give more details how does not works ? , if provide me full details , i will give the proper steps to repair your fax
hope helping you
Mohamed hejazi
work for hp partner
May 05, 2014 | HP Officejet Pro 8600
How to install a printer?
1. Un packing,removing the seals, cartridge set up, print heads setup, cabling set up, power conditions, power grounding etc ..comes under hard ware set up.
2. Loading the software drivers, configure the IP, sharing, scan setup, fax set up though PC etc comes under software set up..
Depend up on models & functions, technology(Dot matrix,Ink jet,laser jet)the installtion procedure will varies.
Thanks for your direct questioning me, but pl give the model Number to give proper installation procedure to help you better...
Nov 26, 2011 | HP Office Equipment & Supplies
Memory low on hp laser jet 3050. Please advise how to fix the problem. Thank you
solution: 1. Clear the fax memory. Here are the steps to clear the fax memory: a. Press the menu/enter button on the control panel. b. Press the > button once to select Fax functions , and then press menu/enter . c. Press or > to select Clear saved faxes , and then press menu/enter . d. Press menu/enter to confirm the deletion. NOTE: In addition to clearing the reprint memory, this procedure clears any fax that is currently being sent, unsent faxes that are pending redial, faxes that are scheduled to be sent at a future time, and faxes that are not printed or forwarded. 2. Enable the settings to print directly to the printer. Perform the following from the PC that has the printer driver installed: a. Click Start , Printers and Faxes , and check for the driver listed for the printer. b. Right-click the printer driver, and select Properties . c. Then click the Advanced tab, and check the print directly to the printer option. Click Apply , and thenOK . After performing each of these troubleshooting steps, try doing a print job and check for the results.
Jun 10, 2011 | HP LaserJet 3050 All-In-One Printer
How do i get my samsung ml-2510 printer back online? it is offline for some reason - was working in the past. tx!
Follow the step:
  • Access "Control Panel"
  • Access "Printers and Faxes"
  • Right Click your Printer
  • Select "Use Printer Online"
Mar 01, 2011 | Samsung ML-2510 Laser Printer
How to receive fax
Instructions Things You'll Need:
  • Phone line
  • Multi-function printer
  1. Step 1 Connect the multi-function printer to a phone line. Most printers with fax capability have more than one phone jack, so make sure you are plugged into the right one.
  2. Step 2 Turn the printer on and access the start-up menu. Pick an answering mode based on your expected usage of the fax capabilities of your machine (see the next steps for more information about this).
  3. Step 3 Put the printer in manual mode if you expect little fax traffic. The manual mode usually requires you to pick up every call that comes to the machine. If you hear the signal for a fax, you push the start button and hang up.
  4. Step 4 Choose the automatic mode if you expect a lot of faxes or have a dedicated fax line. In automatic mode, the printer listens to incoming calls and determines whether they are faxes or voice calls. Voice calls get sent on to your phone, and faxes are picked up by the printer.
  5. Step 5 Select the number of rings you want your multi-function printer to give you before dropping a call. If you are using the manual mode you may want to go with four or more rings. Two rings should be sufficient in the automatic mode.
  6. Step 6 Load paper into the paper tray. Check on the paper level frequently if you receive a lot of faxes.
  7. Step 7 Set the desired print quality, and you are ready to receive faxes.
You should be all set now to receive faxes.
Aug 06, 2010 | HP Officejet 4355 All-In-One InkJet...
Having problem with fax machine
1. Your issue is possibly due to an un-sent message in the queue of the fax spool
a. unplug the fax and wait 30 second then plug it back in the AC socket.
2. check the display window to see if you can fax
3. Select the fax button punch in your fax number if you hear dialing then the fax is sending. Wait for a fax response.
Repeat steps 2 and 3 if not sending.
If this is a multifuncitoning device clear all printing on the PC and try fax again.
Mar 11, 2010 | HP OfficeJet 6310 All-in-One Printer...
How to send fax
1. if it's not already green, press the Fax button
2. load your document
3. enter destination fax number
4. press the Black Start button
5. press 2 to start dialing
6. press Stop/Exit button to cancel fax
Jun 24, 2009 | Brother MFC 210C All-In-One InkJet Printer
Scanning
You can do this through the microsoft word. When you scan your document, your program will ask you where you want your document to go,you can direct it to ms word. you can send your email from microsoft word .easy
Note: it is important to install the software that came with the printer.It is this software you are going to work with to send your scan to ms-word,
Good luck
Jul 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
HP Officejet 5610 Fax Failure
You can try resetting the printer.
Step 1. Unplug the power cord at the back of the printer while the printer is still on
Step 2. Press and hold the # and 6 button on the printer while the power cord is disconnected. And keep holdig the two buttons until you plug in the power back again.
Note : do not release the # and 6 when you plug the power cord back in. keep holding the two buttons until the printer would turn on then turn off or the printer would say anything about "reset"
Step 3. Try sending a fax after the successful reset of the printer
Jun 21, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp5610
hello with witch windows do you work???
Jan 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
