Question about Ruud UBHC Air Conditioner
Ruud achiever 90 plus blower not working
I have a Ruud Achiever plus heater with heat pump. The furnace blower goes on & off and makes a large clicking sound in the unit. Now the fan will not work at all but the heat pump is running fine. I've shut down the system so I don't burn up motors. Also, the fan blower turns freely. The light inside the furnace is continually blinking. Any suggestions? Also, where do you get parts for these things?
  • popeye1260 Dec 07, 2008
    Ruud 90 plus igniter works. burner ignites OK after heating and as the blower turns on there is a few loud clunk a de clunk, clunk noise and then the fan comes on. sounds like a bad solinoid. Looking for help here.
    Problem Solver:
  • 25 Answers
Does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Posted on Nov 22, 2008
Ruud achiever 90 plus furnace-water leaks from the drain pipe
This furnace should condense, as long as it goes into the drain. If it is leaking inside the furnace, there may be a seal that needs replacing in either the pvc drain pipe or concentric drain trap needs resealed.
Feb 21, 2015 | Ruud Heating & Cooling
Ruud achiever 90 plus gas furnace flame goes out after few seconds
This could be water in the hoses that connect to the pressure switch , they should just pull off and blow then out also blow out the pressure switch , this sound like a moisture problem with all the bad weather you h, check air filter is not blocked .
Feb 12, 2013 | Heating & Cooling
My Ruud Achiever 90 Plus not blowing cooled air
Look on the condensor, (outdoor unit) at the very bottom of the rear panel and you should find a red reset button. push it. If that does not solve the problem, and the outdoor unit is running (make sure both the fan AND the compressor are running) then you are looking at a low refridgerant issue and possibly dirty coils.
In that case, clean the coils and have refridgerant added.
Sep 23, 2009 | Ruud UBHC Air Conditioner
Ruud Achiever 90 plus not blowing air
the motor is bad or start capicitor
Aug 29, 2009 | Heating & Cooling
Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Feb 05, 2009 | Ruud UBHC Air Conditioner
RUUD Furnace not coming on
the fuse that your refering to is on the control board indie of the furnace. shjould be a 3 amp. good luck.
Jan 30, 2009 | Ruud UBHC Air Conditioner
The door, you mean the metal cover on the front? if you have the door off and push the safety switch in with your hand everything works fine? I need more info here, but if what I said is right, then the "door" isn't making good contact with the switch.
Mar 05, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
1,949 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
