I'm getting a "Mecha Trouble Edge Alarm" on my sony UPDR150 printer. The images are "shifted to the left about a 1/2 inch when they print leaving a 1/2 inch white space on the print
Checking the gear by taking off both side panels and the panel directly in front of the cutter helped me - in my case I received the error "mecha trouble cutter pos"
problem was, the cable that runs the cutter had fallen off of the pulleys and after a bit of fussing, I was able to get the cable back in place and a working printer.
SOURCE: sony up-dr 100 error 0007
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
SOURCE: Mecha Error 0005
oooohhhh k
1) when you turn the printer on does the printer make a lot a noise and then display "ready"
-If not there may be mechanical issues with your printer
SOURCE: my sony dpp-fp55 leave 2/3 of the paper white while printing
They are thinking the cartridges are dirty or the heads. I am thinking it is a setting for the printer or an actual glitch in the printing program. If you have successfully printed on this printer before, then very carefully go through the settings, looking for print margins settings specifically. This sounds simple but you might want to make sure your paper trays are adjusted correctly.
SOURCE: UPDR150 Thermal Photo Printer: My Sony UPD-150 is printing on only 3/4 of the 5X7...
One of the pins is bent. Its not closing completely so when it prints the heads are not touching the media evenly causing this effect. We have four of these printers and have seen this before. You need to take some pliers and straighten the bent pin in the door to match the one on the opposite side. These pins are located near the top edges of the printer door.
