Question about Kodak EasyShare C743 Digital Camera
C743 You recently commented on the C743 and I like many have the battery issues. They discharge even when the camera is off. You mentioned that there were others out there that were better and maybe even less expensive. Can you suggest one of them and I would really like to have the separate viewfinder that the C743 has Thanks ! ! Zork
  • 3 more comments
  • sisde Oct 28, 2008
    My Kodak XE Easy Share (C743) drains batteries in a few hours...while just sitting idle.
  • yochumd Nov 25, 2008
    Does anyone have a solution to this problem other than buying a new camera?
  • Anonymous Dec 30, 2008
    my c743 drains batteries while idle as well. Any solution for this camera would be appreciated.
  • Bob Jan 12, 2009
    I have the same problem with this camera that I purchased with a warranty from Best Buy. The Geek Squad says that it's normal for a camera to drain it's battery with it off for two days...BS. I have other cameras that don't drain it's battery when it's off for months. I have sent this thing out for repair 4 times now and all they do is clean the lense. Why is Kodak not fixing this problem or at least admitting that it exists. It's a lemon in my opinion and should be replaced under the warranty I purchased.
  • Anonymous Mar 29, 2009
    I've used this kodak c743 twice, I went to use it the other day and the batteries died rapidly, i bought new batteries and they died within an hour, there's obviously a problem with the camera, but of course i threw away the reciept. Kodak is junk, this is my third faulty camera, I'm gonna buy a nikon, I could fix this mess of a camera, but it will most likely break again, JUNK!!
    Problem Solver:
  • 15 Answers
All electronic devices will drain from the batteries connected, but overnight is ridiculous.
What are the features you want?
Do you want a point and shoot camera that fits in your shirt pocket or one that needs a carrying case?
I recommend a point and shoot for everyday picture taking, stay away from the non-standard cameras. Sony (R) is notorius for making proprietary devices that ONLY work with Sony. Which means that you have to pay more for Sony's proprietary converters to get it to work with your computer.
Purchase something with a not so large screen, to keep max. battery life. Also find a camera with a view finder. It may seem a little awkward having your face at your camera while taking photos, but we all did it prior to digital cams.
Search search search, until you find something you like and more importantly... can afford.
Posted on Oct 05, 2008
How big can SD card be for Kodak Easyshare C743 Digital Camera?
You may use any SD card up to 2GB in size. The C743 will not work with higher-capacity SDHC and SDXC cards.
Jul 13, 2014 | Kodak EasyShare C743 Digital Camera
Kodak C743. Loaned to friend, now camera has disk
how big is the memory card you are trying to use?
the max size for the C743 is 2GB
try to format the card in a card reader
Jun 04, 2010 | Kodak EasyShare C743 Digital Camera
EasyShare C743 Digital Camera: I just bought a new 8 gig Kingston SD card for my ...
The C743 is only good to 2 GB other models of Kodak can use the larger cards but not the c743
May 17, 2010 | Kodak EasyShare C743 Digital Camera
Hello i put in new batteries into my camera today and it wont turn on....help! and yes i put the batteries in
Are you using the AA alkaline battery? If yes try to reverse the orientation of the battery instead of positive negative make it negative positive
Now if your using new rechargeable make sure thats the AA Ni-MH this Ni-MH is highly recommended for your camera C743
Nov 11, 2009 | Kodak EasyShare C743 Digital Camera
C743 CAMERA SUTTER BUTTON
there are six screws (#0 phillips) on the sides and the bottom that you have to remove, two per side. Open the battery compartment and remove batteries and leave door open. the front should slip off, you might have to use a small flat screw driver to help the sides seperate. now there are three screws that hold the function button together. with the button out you can remove the old shutter button by GENTLY pushing the two little blue tabs to toward the center and into their little holes. be careful that the button doesn't shoot out and watch out for the spring. reassemble in the reverse order.
Apr 14, 2009 | Kodak EasyShare C743 Digital Camera
Internal Memory is Full
Hi there
Just use the format option in the camera's menu, this will resolve the problem
kind regards and please don't forget to rate us
Dec 13, 2008 | Kodak EasyShare C743 Digital Camera
C743 digital
A Kodak tech told me to use only rechargeable batteries as regular dry cells do not have enough power and will go dead at the most inconvient time.
Jun 23, 2008 | Kodak EasyShare C743 Digital Camera
Kodak C743 Battery Discharging When Switched Off
I would suggest, if under warranty, to take it back to the store or contack kodak for a replacement. Otherwise, start shopping for a new one. There are a ton of great digicameras available for the same if not cheaper than this one.
Apr 25, 2008 | Kodak EasyShare C743 Digital Camera
Kodak EasyShare C743 Digital Camera Logo
136 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
