Question about Hotpoint WMA64 Front Load Washer
Replace belt wma64
Can somebody tell me how to refit my belt on my wma64 as it has slipped off.
Thanx
Phil
  • Hotpoint Master
  • 3,463 Answers
Remove top cover, tilt m/c towards you, this gives you more space to work in, and slip belt over motor pulley first, then gradually ease belt over drum pulley turning the drum with the belt,until it is on.
Keep your fingers from getting trapped as the belt is very tight
Posted on Nov 25, 2008
I want to change fan belt by myself is it easy .?
You can refit the old one if still ok! Or easily replace with a new one! What vehicle is it?
Dec 30, 2014 | Cars & Trucks
Remove drive belt nordic track audiorider r400
see the video and follow the steps with common sense. God bless you
Nov 13, 2012 | Exercise & Fitness
Hotpoint washing machine barrel not turning all other functions OK. Motor, belt drive and bushes look ok new curcuit board replaced any Ideas? Model wma64
could be motor not rotating under pressure. When you say brushes have you removed them from motor to check them, also check they slide in and out thier holders ok, as they may be sticking
Feb 11, 2010 | Hotpoint WMA64 Front Load Washer
Lawnmower keeps slipping power drivebelt over rear sleeve
Usually, when the machine throws belts, the best thing to do is to replace the belt. Sometimes they are worn out or stretched, and you just can't tell it. I had a pristine looking belt on a pretty new mower doing the same thing. I replaced the belt, problem solved.
Best regards, and happy mowing! --W/D-- please feel free to rate this solution! Thanx!
Jul 31, 2009 | Garden
Dru wont turn at all
Hi, welcome to Fixya.
The belt has come off for a reason, and there are a few reasons for it to do so.
1- You have overloaded the m/c
2- It is not draining properly.
3- The main drum bearings have gone. Before replacing the belt spin the drum by hand, and if it is noisy or feels rough , then the bearings have gone.
That means calling an engineer.
4- Worn or broken belt.
To refit the belt, do the following.
Remove top cover, and rear panel.
Tilt the m/c forwards, and support it.
Reach inside and slip the belt over the motor pulley, then start feeding the belt round the drum pulley, it is fiddley, but this is the only way, as you get the belt futher round, it will get very tight, so don't trap your fingers, just keep on going.
If it slips off, start again.
Goodluck.
Plz rate my solution.
Thanks, And a merry xmas.
Dec 22, 2008 | Hotpoint First Edition FEW12 Front Load...
Carriage drive belt
hi pls check ur belt teeths. its getting damaged better u will replace new belt.
Sep 19, 2008 | HP PhotoSmart 1115 InkJet Printer
Replace belt
Remove lid UN PLUG MACHINE FROM WALL SOCKET Undo motor bollts so it can be moved towards drum, GET OLD BELT AND LOWER IN YOUR HAND TOWARDS DRUM THEM MOVE BACKWARDS TILL CLEAR OF DRUM PULLEY ,get new belt and lower so it goes over rear of drum pulley (big wheel)make sure nothing is in drum,put one bolt of motor in loosely and roll belt over motor pulley wheel slowly forcing towards you if working from front a bit until ribs on belt are in grooves on both pulley wheels,Tighten up all motor bolts job done test it
Sep 15, 2008 | Hotpoint WMA64 Front Load Washer
Owners manual
remove bottom plate, remove brush roll. slip new belt over motor shaft then onto brush roll. refit brush roll and bottom plate. its just meccano
Mar 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Hotpoint WMA64 Front Load Washer Logo
268 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
