Question about Aiwa Televison & Video
TRYING TO FIND A REPLACEMENT BATTERY FOR AIWA DVD PLAYER MODEL# BP-ZVL01
5 Suggested Answers
  • 619 Answers
SOURCE: Replacement DVD Player Battery
recommended web site by fixya : www.12vAdapters .com
Posted on Jan 11, 2008
SOURCE: DVD Player
Sorry the company is debunked.. no longer exist..... You and me are both screwed for buying these.
Posted on Jan 17, 2008
SOURCE: GPX DPL705 Replacement Battery
You can call GPX @ 314-621-2881 press #2 for parts and accy's. Per their website gpx.com
Posted on Apr 28, 2008
  • 55 Answers
SOURCE: need replacement battery
You can try googling the internet or contacting customer support to see if U can get a replacement battery. Is the battery taking some kind of a charge? If it is taking a charge that lasts a short time, U can get by by checking the players ac in voltage. Example: If it is 9 volts, U can get a 6 d cell battery holder from the internet, and go to batteryspace.com and go into wires and connectors. Get the two prong wire that has an two alligator leads on the other end. You can buy a universal 6V-12V battery pack charger from this site, and get the powerizer 10000 mah rechargeable d cells to boot. U might want to use the .9 Amp setting, or the 1.8 amp setting if yopu are feeling adventurous. The powerizer batteries have sometimes leaked, especially the smaller C size when using this setting(1.8 amp) The site also sells compatible tips that will fit that connector. If the battery cannot take ANY kind of a charge, what kind of battery is it? If it is built in, youre in luck. If it is a clip on detachable type, U have a problem as the cutoff voltage with those type of players is typically higher on the ac in jack since the player isnt recognizing that discharged battery pack is still connected. For that, you could try a 8 d cell battery holder and just use alkalines if you don't want to risk cell reversal with your rechargeables, or just get the 8.4 Volt battery pack that site sells. I also recommend accupower evolution low self discharge rechargeables, found at thomas distributing.com id U have the cash. Good luck, and let me know how it turns out. Hint: the voltage rating of the battery power supply listed on the player may be lower than the AC in jack. Consult your manual. Use the specifications used in the battery listed. A 7.4 lithium ion pack or a 7.2 nimh battery pack will work if it is basically a 9 volt circuit. A 7.4 litium ion battery included with the player would mean you would use 6 D cells inserted in a battery holder hooked to this unit.
Posted on May 01, 2009
SOURCE: replacement battery for Protron PDV-288 portable dvd player
I have a rechargeable battery pack that you can purchase.
Posted on May 25, 2009
How to connect an aiwa music system to sony dvd player
Just plug the audio output of the DVD to audio input(AUX) of Aiwa system. Select the player in the Aiwa( Aux, DvD, and Phono)
hope that helps out!
Jun 09, 2011 | Aiwa Audio Players & Recorders
How do i connect a aiwa 2.0 speakers to philips dvd player?
In general, speakers don't connect directly to a DVD player (model unknown) as DVD players generally have no way of amplifying a signal to speaker level.
Assuming the speakers were self-powered, you would not be able to control the volume since DVD players generally have no output controls.
I have found nothing online that matches "aiwa 2.0" as a unique speaker model.
Can you re-describe the speakers and the DVD player piece?
Feb 12, 2011 | Audio Players & Recorders
Battery does not hold charge. Where can I find a
I suggest to purchase another brand , PROTRON no longer on the market , it belongs now to SPECTRONIQ,and their customer service is very bad, they will tell you that the BATTERY replacement is out of stock at the moment but its on order , Ive been like this trying to get a replacement for my PROTRON for about 3 years !! AJ
Dec 01, 2009 | Protron PDV-288 7" LCD Portable DVD Player
Replacement rechargeable battery for aiwa am f70 minidisc player
The original part number for this battery is U-0130-979-U and can be found at the following website for $73.13:
http://www.encompassparts.com/products/?AIW87B30111010
Nov 08, 2008 | Aiwa AM-F70 Personal MiniDisc Player
Setting the clock
Use an Aiwa Hifi Remote Control...Turn on the L300 (without any DVD on the player). Wait until in the TV appears "No Disc" Open the tray and put a DVD from other region (not zone 1), don't close the tray!!!. On the remote control of the Aiwa press the "Clock" button, in some remote control you must do a button combination like "Shift+9" (Is the combination to see the clock, do the combination fast), and in other model of Aiwa remote control doesn't appear the clock button, you must try with the "random" button. If you do it right, in the corner of TV where "No Disc" appears it will say "adjust complete".
Jun 15, 2008 | Sansui VRDVD4005 DVD Player/VCR
Sungale portable dvd model number pd580
I need a battery for a Sungale DVD player Model Number PD580 how can I get one.
Apr 28, 2008 | Televison & Video
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
Televison & Video Logo
41 people viewed this question
Top Aiwa Televison & Video Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
