I have a cougar c.600.2 1200Watt 2channel mosfet amplifier that was workin 4 about 30mins than it stoped and now wer it had a green pwr/prt light it is now red and doing nothing can you help me plz n thank you
  • Anonymous Apr 21, 2009
    i have the same problem
simard2
  • 124 Answers
SOURCE: Green light is off and
Most likely you need to check the Fuse(s) and check all connections including any RCA's and Speaker Wire. Do that and get back to me.
Thank you for using Fix Ya!
Good Luck!
Don't forget to rate the overall satisfaction of this response or solution.
Posted on Feb 01, 2009
  • 187 Answers
SOURCE: panasonic th-42pd50u no pic no sound but pwr light on
Replace the mainboard, it is going to be damaged, there is a chance it could be the powerboard but it is quite remote to take into consideration.
Posted on Jun 13, 2009
solasknows
  • 199 Answers
SOURCE: my xbox just stoped today. it was workin fine last.
dont take the sticker off microsoft has warranty on it send it they will fix it
Posted on Jul 22, 2009
ctech217
SOURCE: no sound when input cables are connected
you have to check the input resistors
Posted on Sep 19, 2009
  • 106 Answers
SOURCE: green call, task menu & red end call/pwr light on always
call at&t sounds like your phone has a defect
Posted on Feb 18, 2010
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
MY KICKER ZX 750.1channel amp "FLIP FLOPS" from protected mode(red light) to normal (green light) every 2 seconds.
Are you getting any sound output at all from amplifier?
Is there a popping or banging coming from speaker?
It could possibly be a faulty output mosfet that is ocillating cause DC to leak onto the speaker output causing it to flip into protect.
please advise
thanks,ben
Sep 27, 2010 | Kicker (ZX750.1) Car Audio Amplifier
How to find out the radio wiring harness color codes on a 1997 mercury cougar
hi
1997 Mercury Cougar Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Black/Orange
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Dark Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5′ x 7′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Pink/Light Blue
Right Rear Speaker Negative Wire (-): Brown/Pink
Jul 11, 2010 | 1997 Mercury Cougar XR7
X621 excelon amp has red light on, stoped workin all of the sudden now a minimum sound exports with a bit of static. do i reset it? what do i do and how?
If disconnecting all power wires, and replacing all fuses (including inline ones) doesnt reset it. then its toast. Hate to break it to you :( Contact the manufacturer if you feel it is under warranty.
Apr 14, 2010 | Kenwood Excelon KAC-X521 Car Audio...
No sound when input cables are connected
Sep 19, 2009 | Car Audio & Video
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
Green light is off and red prt light flashes once I have a crossfire 1000WT
Good Luck!
Feb 01, 2009 | Crossfire VR1000D Car Audio Amplifier
Mercury cougar
Constant 12V+ Black/Orange Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Light Green Dimmer n/a Amplifier Remote Dark Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Pink/Light Green Left Rear (-) Tan/Yellow Right Rear (+) Pink/Light Blue Right Rear (-) Brown/Pink
Sep 28, 2008 | JVC AM FM CD DET FACE CAR STEREO
375 people viewed this question
 Grubhead
Grubhead
