Question about Dishwashers
My dwh b10 Whirlpool dishwasher is not draining. This happened before, and the guy that came out told me what to do if it ever happened again, but since I have the memory of a goldfish it has slipped my mind.
4 Suggested Answers
marked
  • 6487 Answers
SOURCE: Whirlpool DWH B10 - under IKEA
Try checking this link for the user manual http://www.serviceforce.co.uk/pdf_search.asp
Hope that helps..........
Posted on Jul 24, 2008
  • 423 Answers
SOURCE: is this hot or cold feed
This dishwasher should be connected to the hot water line under the sink. If it is connected to the cold line, you will have very poor cleaning. The hot water should be 120 degrees (F) minimum and less than 140 degrees.
Posted on Apr 18, 2009
  • 574 Answers
SOURCE: Whirlpool / IKEA Dishawasher DWH B10 - castor wheel
make sure there aren't any screws through tabs at the top front of the washer that fastened it to the counter top.
Posted on Jan 04, 2010
  • 1456 Answers
SOURCE: DWH B10 F3 - no heat.
Hello
The majority of dishwashers are not connected to hot water from the mains but heat up the water internally using the heating element, located in the tub of the dishwasher, controlled by a thermostat. When the dishwasher has a fault with heating, the program will run but not complete and will show an error code on the display panel. Dishes won't be cleaned properly and the detergent won't dissolve.
If your dishwasher does bring in hot water externally from the mains to check the water is warm and there are no problems with the inlet. If the dishwasher heats internally then it is most likely a faulty heating element or thermostat. A fault like this will usually require a replacement part and a repair, but you can check the heating element with a voltmeter to ensure that it is the cause of the problem before calling out for a service engineer.
Posted on Sep 10, 2011
Just need to know how to operate DWH B80
Hi Wendy the link below has two user manual downloads on it, I hope you find what you're looking for....CHEERS..
http://lastmanuals.com/manual/WHIRLPOOL/DWH-B80-W
Mar 24, 2016 | Whirlpool DWH B80
Jul 24, 2008 | Dishwashers
DWH B10 F3 - no heat. Stops at rinse and beeps + flashes 3 times
Hello
Sep 10, 2011 | Whirlpool Dishwashers
Whirlpool dwh b00 doesn't dry well
Look in the following areas:
Is the washing machine spinning well enough to wring out clothes?
Move the dryer away from the wall, pull the hose off of the back, activate the dryer and form an opinion about the volume of air flow....Connect back up, activate again, go outside the building and verify VERY SIMILAR air flow outside the building. Often screens block up and restricted air flow diminishes drying ability.
May 04, 2011 | Dishwashers
Whirlpool dwf b10 manual
Try this site
http://www.whirlpool.co.uk/support_instructions-for-use_instructions-for-use.content.html
then enter in DWH B10 and you should be able to download a PDF manual
Oct 12, 2010 | Dishwashers
Jan 04, 2010 | Dishwashers
Is this hot or cold feed
Apr 17, 2009 | Dishwashers
Whirlpool dishwasher installation
FOUND IT!!!!!
There is a white plastic screw in front of the dishwasher to estend the back leg!!!!!
Whirpool people are crazy!!!!
Max
Aug 17, 2008 | Dishwashers
Dishwasher
It sounds like it, yes. My guess would bedthe heating element. Does it have a "cold was" program you could try? If it still trips the fues it may be the motorr that is broken.
Nov 07, 2007 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
115 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
