Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Picture blinks on and off but not when you go through the vcr We have the same problem with ours. It blinks on and off. However, if you use the vcr or dvd player, it stays on. Thank you.
  • Mitsubishi Master
  • 19,396 Answers
It is either an internal error or a cable problem.
If this happens when you watch channels fromn an external receiver box, then replace the cable.
If it happens watching regular TV channels, then it is an internal wiring or a connector, probably wiring to aerial input or tuner board.
If you need to call a technician you can use the number listed on the user manual.
Thanks.
Posted on Sep 15, 2008
Our remote control is not reading to our tv we need a three digit code number
Hello
Three digit universal remote control codes for sanyo are:-
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote control codes for sanyo are:-
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Dec 12, 2010 | Sanyo DS31520 31" TV
Good day: Our Tv picture is rolling when
Either the tracking will be off set on the VCR or the heads may need cleaned or the pinch roller in the VCR will be worn & need replaced.There could also be a possibility the guide arms are not fully in position in the VCR.
Oct 23, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
We are unable to get video (picture) on our TV, when we hook up to our new DVD/VCR combo. The combo doesn't have an S-video port and our TV does. We get perfect sound though.
Your TV should also have a regular composite video input jack (yellow) in addition to the s-video input. Use that input instead of the s-video. The video won't be quite as clear as with s-video, but you have to work with what the combo gives you.
Apr 22, 2009 | Zenith C27A24T 27" TV
Picture blinking on a Sharp Quos HD TV
A lot of times with recorded tapes, the tape that's inside doesnot work well with vcr s. I have had this problem with old and new vcrs and if you keep trying then the device will eventually eat the tape.....
Apr 10, 2017 | Televison & Video
I have connected my DVD/VCR to my Samsung 32 inc television but I get no sound
I had a strange issue yesterday too.
Our Samsung DVD/VCr all in one combo did a similar thing.
I used the HDMI cable for the DVD into the TV input labeled HDMI/DVD. That worked okay.
But the VCR part didn't work.
At one point I got sound but no picture. Using the RCA cables in the back on another input "Component 1"
I was trying to squeeze the best picture out of the player using the S-VHS cable.
I thought it did picture only, but the Plasma seems to be more picky about input sources.
I got everything to work keeping the DVD as a separate HDMI to Plasma TV feed.
The VCR was 3 RCA's Yellow (picture) red and white for stereo sound.
I then reset (toggled through the inputs to "reset" the TV.
It finally worked but I was two days mulling it over.
See if this works for you.
My TV was a Panasonic Plasma, but shouldn't matter.
Skip the S-VHS line and connect the inoputs with the TV off.
You MAy need to go into the input of set up menu on the TV (ours had a wrench as an icon) and set the Component 1 or 2 to "VCR".
Aug 04, 2008 | Samsung Televison & Video
Is the VCR sitting on top of your TV? This has caused problems in the past...accordianman
Feb 18, 2008 | Panasonic PV-8400 VHS VCR
Can't get vcr to record
Make sure you are giving the VCR a signal.
If using a RF source (cable or antenna), make sure the VCR's tuner is set up for the right type and channels.
When trying to record put the TV's input to the VCR to make sure it is getting what you want.
Jan 17, 2008 | Toshiba W522 VHS VCR
WD-52725 TV loses picture while playing DVD but not sound
replace DM or try to fix it.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Jan 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
Sep 24, 2007 | Zenith XBV442 DVD Player/VCR
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
