Question about Cameras
I have a fujipix 6.3 mega pixels camera. All of a sudden the lense locked up and the camera won't open anymore so I can't take any photos.
    Genius:
  • 1,550 Answers
It indicates that the sensor is not working properly . It indicates that there is some obstacles in lens that why it is getting locked up .
So if you are able to unscrew and see whether sensor is working properly .
If you cant find any problem with the sensor then your problem is complicated .
So no other choice you need to contact the fujipix company to solve it .
Thanks for using Fixya .
SAM ANDERSON
Posted on Sep 15, 2008
  • SAM ANDERSON Sep 16, 2008
    Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. You can also blow with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
    Gently tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens.
    Genius:
  • 3,422 Answers
HI,
First try normally reseting your camera by removing the batteries and mem.card for 2 min and then insert them back and turn it on.
  • Priya darshan Sep 15, 2008
    Next try compressed air.turn off the camera blow air between the lens turret
    and the camera body. It should remove all dust and sand. Turn the
    camera on.
    IF you still face the problem try these steps:
    Try forcing the camera lens.Turn off the camera. Place it on the back
    with the lens facing up and take a look at the spacing between the lens
    and the lens housing.
    If you notice
    that the gap is not even all the way around the lens, the problem
    should be easy to fix. This type of a problem usually occurs if the
    camera was dropped while the lens was extended.
    Simply - VERY
    GENTLY - press down the lens on the side where the gap is the biggest.
    You should hear a "click" as it pops back into place. Try powering the
    camera back on.
    Tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
    The last thing you can do is switch to a 2500 mAh Nickel Metal
    Hydride rechargeable batteries you may notice a difference.It gives the
    camera with zoom mechanism more power than what actually is required.
    Even after trying these steps if you still face the problem then the problem is a blocked lens mechanism which will require a physical presence of a tech to fix the problem.
Exilim camera memory full when few pictures taken
Have you fitted a memory card?
The camera will only take a few photos using its own memory.
It takes: SD Memory Card, SDHC Memory Card , SDXC Memory Cards.
If you have fitted a memory card it may be faulty and you will need to buy another.
Jul 27, 2014 | Casio Exilim Ex-h30bk Ex-h30 Black Digital...
Reducing Pixels on Canon Ixus 105
Follow the instructions on page 68 of the manual available from here.
Dec 30, 2012 | Canon PowerShot SD1300 IS / Digital IXUS...
My canon a6o intermittenly gives me smudgy display and pictures. Ia there any quick fix for should I bin it?
If it has low Mega Pixels it's worth binning if it has high take it to a camera shop to get it looked at. Good Mega Pixels 8 - 14 rubbish mega pixels 2 - 6. hope this helps!
Dec 18, 2010 | Canon PowerShot A75 Digital Camera
On the Panasonic 12 Mega Pixel luminix camera, can
If the computer has the appropriate slot for your card, then the answer is yes.
Feb 11, 2010 | Cameras
All functions except picture taking work on camera
Problem with lens assembly. No user solution. Contact service.
Aug 17, 2009 | Sony Cameras
With 5-megapixel camera, I want to capture maximum resolution.
how I get maximum resolution by 5 mp camera with small photo.
my friend mega pixel relates to the print out u want out of ur photo file,on the monitor screen everything looks same if u dont zoom too much ,
for 5X7 print 1 mega pixel photo looks fine and more than enuff if u want a 5X7 print out of it
for 6X8 and 8X10 2 mega pixel is ok and for further enlargements u need higher mega pixel
or if u need output on large LCD screens of like 46 inch and 52 and 60 inch then also u need good resolution pics to display properly other wise pixelation will appear
so how can i help u more in this pls rate me FIXYA for this if u like
Mar 17, 2009 | Mercury Electronics CyberPix S-555V...
Focus
The little white ring on around the lense, that is the focus on the camera. Now the other issue with picture quality is the camera itself. I believe this camera only 1.3 mega pixels to get a less blurry higher quality pic u should use a higher mega pixel camera
Nov 12, 2008 | Logitech Quickcam Chat Webcam
Sony cyber shot dsc w55 7.2 mega pixels
turn on when lense extends take hold of the end of the lense and gently twist and pull the lense you may hear it click do not force the lense then turn on and off again this should solve the problem.
Aug 07, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cybershot 7.2 mega pixels suddenly stopped working, I can see the photos I have taken but can not take new photos, the disply read "Access" then says to power off and on again. I have...
Lens of camera is not being open properly, so it gives "access" message. Try this trick, while puching power up button, tapp the lens or pull upward. Please don't give much force as it can be damaged easily.
May 28, 2008 | Cameras
Cameras Logo
50 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
