Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Hello Slinte, I've seen a couple of the shaky blue screen issues reported, but can't tell what the most likely cause is. And possible fix? Is this a capacitor issue or power supply or something else? My set is about 3.5 years old, and this is the first problem, other than changing a couple bulbs. The current buld is a clone, not OEM, would that cause the board to go bad prematurely? Please let me know your thoughts. Thanks, Joe
  • 927 Answers
Good Day;
NO, the lamp will not cause this but the light engine or the cap's problem on the theboards will.
Good Luck, big IRISH.
Posted on Sep 28, 2008
I've had my compaq presario cq61 for about 2-3 years. A while back it would occasionally have a kind of shaky/blinky screen but just in the past week it's like the screen has stopped working.
The problem may be due the graphics card or data cable or backlighting.
The data cable can be severed over time though opening and closing the display. This can be replaced.
The backlighting/inverter dies, some-times the windows desktop screen can be seen if one looks carefully. This can also be replaced.
Try connect your notebook to another computer's monitor via VGA or HDMI out.
If this works then the problem lies with your LCD screen.
Take care!
Sep 11, 2012 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
My engine management light keeps coming on on my Rav4 (2001) I have had 2 sensors changed - and a new cat - but the fault codes keep saying it is the cat - please help!
The ECU is reporting the cat error code because the O2 sensor(s) outputs are telling it so. This MIGHT be the O2 sensor(s). You say two sensors have been changed, If these were the O2 sensors, then there is another engine issue to fixed.
The usual reason is that the engine is passing excess hydrocarbons into the exhaust, typically because its burning oil due to exhaust valve guide wear or/and worn valve stem seals. For a 2001, you've probably done around 200,000 km, so valve guide wear is likely. A head recondition is the only cure if this is the case. If you see blue smoke on starting, that's burning oil.
Related issue is worn piston rings: also causes excessive oil consumption.
Another problem is leaking (ie dirty) injectors. Most garages can clean them.
Another problem is the engine is running too lean. This can be caused by a dirty air cleaner or any number of other issues.
Sep 16, 2011 | 2004 Toyota RAV4
My screen is shaky and cloudy
Hi Yugtob,
Seems like you're having problem with the display of your computer. There are some reasons why your system displays shaky and cloudy screen. Sometimes it caused by a corrupted video driver or system has a faulty screen (hardware failure). Going to the bios and installing the latest driver are basic diagnostics that you can apply to check if this is a software or hardware problem.
Try to replicate the issue by going to the bios
1. Turn off the computer.
2. Boot the computer then start tapping the F2 key.
3. Inside the bios please observe the display if it's still shaky or cloudy.
--> If it has the same issue, system has a faulty screen and needs to be fixed and replaced.
--> If no issue, just reinstall the video driver.
How to reinstall the video driver.
1. Download the driver here:
2. Go to the video section. Then select the operating system that corresponds to your computer.
3. Save the .exe file to your desktop.
4. Install the driver then restart the computer.
--> if you're still encountering the same issue try to perform OKR to set the computer back to the default factoring setting.
Please visit my link to have the complete guide for the One Key Recovery (OKR).
Dec 17, 2010 | Lenovo 3000 Y410 Laptop
Missing parts bogen 3035
Try for that part. There is listed the widest selection of Bogen parts and support more models than any other web site I’ve seen. There are losts of pictures to help find just the right part.
Jan 16, 2010 | Photography
2003 gmc envoy engine light flashing, car shaky when i start it or come to a stop and little hesitant when driving - took it to advance auto machine said cylinder 3 misfire what cause this - i have never...
it should continue to drive, there is a possibility of catalytic converter damage or futher engine damage if it is an engine mechanical issue
Nov 24, 2009 | 2003 GMC Envoy
Blue Convergence on Toshiba 42H82 42-Inch
it should just need new STK392-110 ICs which is actually not very difficult. You will need two ICs both STK392-110 and you can get replacements at the following link and they provide instructions on how to remove and replace Convergence ICs.
Heres the link.
Oct 22, 2008 | Televison & Video
No display
Hello. By what you`ve said, i would suggest you to get the computer to a service. It seems like a motherboard problem
Jul 03, 2008 | Toshiba Satellite M35X-S349 Notebook
Lines on screen of HP Pavilion zd7360us
Hello, please report your story at so your computer model may be added to any future legal suits.
Jan 15, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Trouble with the red cannon
Hello, is the blue blur the only blue on the screen? The reason I ask is because the vertical defection to the blue CRT might be going bad and producing a blue line across the screen. I doubt that it is a convergence problem, but it may also be a magnetism problem and you may need to degauss your set with a degaussing coil (check ebay for specials on this device). I have seen a lot of the projection TVs end up needing to be demagnetized (degaussed). Try degaussing it first and then look at the possibility of a vertical deflection problem and then possibly a convergence issue.
Sep 26, 2007 | Toshiba 50H72 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
